AC codes 14,23, 32
Old May 24, 2021 | 06:56 AM
xk810024's Avatar
Default AC codes 14,23, 32
Hi,
My AC isn't working and when I checked the level of refrigerant it was very low. I recharged it and the AC still doesn't work.
I ran the diagnostic and my AC has 3 error codes:
14 Water temperature input malfunction Instrument cluster output Refer to PDU
23 Refrigerant pressure switch malfunction Harness / connector fault Switch open / short circuit Refer to PDU23 Refrigerant pressure low refrigerant charge *Leak from damaged pipe or joint Rectify as required and recharge system
32 RH fresh / recirc. potentiometer fault Harness / connector fault In certain circumstances the servo motor may over-travel and cause further logged faults. This may be cured, following fault rectification, by cycling the ignition ON-OFF-ON 3 times Refer to PDU
How am I supposed to refer to the PDU? Any suggestions on how to proceed would be helpful.
Ambrose
Old Jul 10, 2021 | 09:16 AM
drmike's Avatar
Did you ever resolve your error 14? You can guess why I'd like to know
chillyp
Sep 9, 2021 06:52 AM
Old_Doc
Sep 28, 2014 09:27 AM
johns55
Aug 16, 2014 03:44 PM
mgb4tim
Jul 7, 2014 09:22 AM
e1rfw01
May 10, 2014 09:03 AM
