AC problems, help needed
Old Aug 11, 2014 | 09:48 PM
johns55's Avatar
Default AC problems, help needed
I have a non functioning AC system. I checked for climate system codes and got the following:
11. Motorized in-car aspirator malfunction Harness / connector fault Sensor open / short circuit Panel fault codes are not stored for motorized in-car aspirator motor failure.
14. Water temperature input malfunction Instrument cluster output Refer to PDU
23. Refrigerant pressure switch malfunction Harness / connector fault Switch open / short circuit Refer to PDU23 Refrigerant pressure low refrigerant charge *Leak from damaged pipe or joint Rectify as required and recharge system
44. Defrost vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
Any and all help troubleshooting these codes and possible solutions would be much appreciated. The car is a 2000 XK8.
Old Aug 12, 2014 | 05:47 AM
There's a combination of faults in the list relating to both temperature and distribution. What are the symptoms that set you off on this code search?
1. inadequate cooling
2. a problem with directing airflow to screen, facia or footwells
Old Aug 12, 2014 | 06:31 AM
johns55's Avatar
Unfortunately, I posted this when I'm away from the car for the week. The AC didn't work when I purchased the car about three months ago. I get warm air out of the vents, and also, it seems even if I turn the heat down to it's lowest setting, I get some heat out of the footwell vent and I think through the dash vents.
I remember spending a little time going through the different airflow positions and they all seemed to work. Switching from defrost to dash vent to floor vent, etc.
Old Aug 12, 2014 | 09:15 AM
Gus's Avatar
Gus
You should first check the refrigerant level first. This car 2000 xk8 is equipped with a pressure switch that when the pressure is low the A/C it will not run. Look at the last page and you will see item #5 that is the pressure switch. I had to replace mine.
Link http://www.jagrepair.com/images/Auto...s/ACSystem.pdf
Do this first then look into the other codes.
Old Aug 12, 2014 | 09:59 AM
batroute's Avatar
+1 - first thing to check should be the gas charge.
Old Aug 12, 2014 | 10:58 AM
wolfpck1's Avatar
my vents also pass a little heat thru if i dont set the temp to low b4 turning the climate system off.
Old Aug 12, 2014 | 03:50 PM
johns55's Avatar
I'll be back with the car on Friday. I'll bring it in to a local shop and have them check refrigerant level. If that's ok, could that point to a bad pressure switch?
Old Aug 12, 2014 | 04:03 PM
DaveInVA's Avatar
As I found with mine if its empty or nearly empty you will have to have the system vacuum pumped before adding new refrigerant. Otherwise there will be enough air in the system to keep the temp from getting down where it should. On mine just adding it to get the system pressure right got the vent temp down to about 58-60 but then getting it pumped down and all new stuff got it closer to 50.
Dave
Old Aug 12, 2014 | 05:57 PM
Gus's Avatar
Gus
Yes that switch has failed on mine and others on the forum.
Old Aug 16, 2014 | 03:44 PM
johns55's Avatar
Thought I'd update the thread. I took the car in and had the AC system evacuated and recharged. They also added dye. The AC blows ice cold right now. Hopefully, it will stay that way.
Thanks for all the help.
Paradigm
Jun 15, 2019 05:59 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
gene1
Sep 3, 2015 08:04 PM
gene1
Aug 27, 2015 09:35 PM
divingmom
Aug 25, 2015 07:54 PM
