Adamesh hood vents.
Old Oct 4, 2013 | 07:32 AM
philhef's Avatar
Default Adamesh hood vents.
I really want hood vents on my XK8 and I've given up finding an XKR bonnet. Adamesh sellers these and they don't require a rolled edge, just holes cut in bonnet. I think they're actually paragon vents.
Has anyone installed these and what precautions are necessary to protect the engine from any water from rain, or washing? I know there are electricals and such in that area.
Or is it possible to simply get a real set of XKR vents and fit those ? I prefer them. The edges would not sit flush but would that be an issue?
Old Oct 4, 2013 | 07:35 AM
philhef's Avatar
Installed
Old Oct 4, 2013 | 07:36 AM
philhef's Avatar
Holes cut.
Not my bonnet. From the website!!
Old Oct 4, 2013 | 07:43 AM
WhiteXKR's Avatar
Originally Posted by philhef
What precautions are necessary to protect the engine from any water from rain, or washing?
Make sure your coil covers are not cracked, have seals in good condition and are properly torqued.
Old Oct 4, 2013 | 07:53 AM
ccfulton's Avatar
There is no changing your mind once you've put those on...
Old Oct 4, 2013 | 08:26 AM
philhef's Avatar
I know. I may opt for a set of factory vents and just let edge sit on top. These do too.
I'm also keeping an eye out for a new hood/bonnet. There's one on ebay but my body shop guy says it'd be a bear to fix. It's really damaged. But it's cheap.
Old Oct 4, 2013 | 08:52 AM
Jag#4's Avatar
Lights up and only $42!
Plasmaglow LED Hood Scoop Kit - JCWhitney
Old Oct 4, 2013 | 10:07 AM
philhef's Avatar
Originally Posted by Jag#4
Wow!! I'm ordering right now!!
Old Oct 4, 2013 | 03:44 PM
giandanielxk8's Avatar
I think the XKR factory ones look better. You might as well just order the factory ones and have the holes cut. You'd just have to get the part number and the precise location to cut the holes.
Old Oct 4, 2013 | 05:48 PM
enderle's Avatar
Default disagree
Without the indent the factory vents are going to look like crap. They are basically snap on plastic parts and you aren't supposed to see the edges. If you want the factory vents get the factory hood. The vents you are looking at work better if you are just going to cut holes.
Here is a cheap XKR hood, it needs some work but you are going to have it painted anyway:
01 02 03 04 05 Jaguar XKR x K R Hood Genuine Factory Original | eBay
Here is a picture of the edge of the factory vent, it is cut to nest in the indent in the XKR hood.
Old Oct 4, 2013 | 07:21 PM
I didn't know that.
Basically, phil, don't give up on getting the XKR bonnet.
Old Oct 4, 2013 | 07:33 PM
Jag#4's Avatar
Attachment 57078
Holes cut.
Is it just me or is one hole cut higher than the other?
Old Oct 4, 2013 | 08:50 PM
enderle's Avatar
Default Just you...
Just you I think, as they look even to me. But those are some honking big holes. I've seen these vents though and done right they are very distinctive and likely suck a ton more heat out. I know my vents blow like a hooker expecting a thousand dollar tip.
OK, I need to get off the computer when I'm drinking...
Old Oct 4, 2013 | 09:43 PM
philhef's Avatar
I know this, that's why I'm looking for an alternative. I've been watching that bonnet for a couple months and made an offer but he's not budging on the price. It's really damaged and would take a LOT of work to be useable. Looks like hail damage and a possible impact to the front.
And the factory vents can be fitted with some work, but there will be a ridge standing proud of the bonnet. Unless someone can roll the edges there's no way to make them totally factory. I've processed this for months!!
Old Oct 4, 2013 | 09:46 PM
philhef's Avatar
Lmfao!!! My best posts are after a couple, or actually many!! Lol
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
XJ8JR
Oct 2, 2015 12:13 AM
goingjag
Sep 30, 2015 09:27 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
