Adapt xenon genuine headlight help
Old Jul 10, 2014 | 05:49 PM
tanngo's Avatar
Default Adapt xenon genuine headlight help
hi guys, 2001 Jaguar XKR 'I have an offer for a set of two xenon headlights 2003 XKR complete "anyone know how to adjust the cables
Old Jul 10, 2014 | 05:53 PM
tanngo's Avatar
Adapt wires
Old Jul 10, 2014 | 06:42 PM
giandanielxk8's Avatar
Tanngo bought a set of Xenon headlamps and is wondering if anyone knows how to adapt them to the wiring of the stock unit.
Am I right in thinking that he needs to buy a ballast?
Old Jul 10, 2014 | 06:52 PM
tanngo's Avatar
Gracias giandaniel , están completos los faros , con transformadores . Las fichas son distintas de las ópticas ' tengo que conseguir diagrama de cables de las nuevas para adaptar a mi ficha ' perdón a todos por idioma " gracias
Old Jul 10, 2014 | 06:54 PM
tanngo's Avatar
Fotos adjunto
Old Jul 10, 2014 | 11:47 PM
He says the headlamps are complete and include transformers. The connectors are different from those on the lens (optics). He needs to acquire the wiring diagram to adapt to the new lamp's connectors.
I think this is what he means. I had to dig out a RAE dictionary because some of the words are used differently between countries.
Old Jul 11, 2014 | 12:39 AM
tanngo's Avatar
Thank You very much giandaniel , perfect translation .///// Gracias ,muy agradecido . Es perfecta la traducción e interpretación , espero ayuda ' necesito cablear / Perdón a todos , soy de argentina .
Old Jul 11, 2014 | 01:00 AM
XKRacer's Avatar
You have to make a loom up...... What I do if I can not get a hold of the original plugs is using speaker female spade connectors attach wires to the light, on to the wires fit a plug of some description which is weather proof (easily bought on ebay) do not cut the oiginal plug off but splice into the loom with more wires and attach the other end of the plug. Fill the plug connection up in the lamp with silicone so the spade connectors can not touch...
Old Jul 11, 2014 | 01:28 AM
tanngo's Avatar
La 2001 conector halógena , tiene los mismos colores de cables que faro xenon nuevos ¿./////// My 2001 halogen connector has the same colors of wires new xenon headlight .. Not , which leads to follow .
Old Jul 11, 2014 | 01:39 AM
XKRacer's Avatar
Yes you will have to decipher what does what, this is not hard just connect the earth and a power source (battery) and take notes. The only thing you will not be able to do is rig up the auto leveling but I never worry about that.
There are wiring diagrams in the How To section at the top of the forum..... I did use to have the pin out written down but I cant seem to find them
Old Jul 11, 2014 | 02:04 AM
tanngo's Avatar
My big question is ... can place genuine xenon headlights, halogens in 2001 jaguar? .. just a matter of wiring?,,, seems you can "" "" gives me joy 'was concerned . My jaguar 2001 xkr halogeno
Old Jul 11, 2014 | 02:19 AM
XKRacer's Avatar
Simple answer..... Yes
Old Jul 11, 2014 | 02:29 AM
tanngo's Avatar
Thumbs up
Gracias , xkracer , giandaniel /
Old Jul 12, 2014 | 09:24 PM
tanngo's Avatar
Hola , ayuda para traducción ' ... Giandaniel , instale los faros como me indico xkracer ' al encender unidad faros xenon , automáticamente suben y bajan , no tengo equipo de autorregulación en 2001 xkr , donde debe nivelarse regulación faros ' , sorry " gracias
Old Jul 12, 2014 | 11:06 PM
Tony, he installed the lamps as per your instructions. He said upon turning on the headlamps, they automatically go up and down, (I imagine this looks like the car is blinking) and he doesn't have auto-regulation device/module/whatchamacallit, on his '01 XKR. Where is he to set the level on the new lamps?
Old Jul 13, 2014 | 02:42 AM
XKRacer's Avatar
I must admit I dont recall having those issues, the motor simply did not work, let me look back at my notes and I will get back to you
Old Jul 13, 2014 | 07:22 AM
tanngo's Avatar
Hola , gracias chicos , funcionan perfectas , motor eléctrico , las luces encender se ajustan automáticamente ' xkr 2001 sin regulación de nivel , sistema se ajusta a nivel al encender , luego se establece un pocos bajas . Yo pensé que motor no funcionaria ,,,, muy contentó .
Old Jul 13, 2014 | 04:15 PM
tanngo's Avatar
are very low. ? review
Old Jul 13, 2014 | 04:21 PM
tanngo's Avatar
Están muy bajas ...?..
Old Jul 13, 2014 | 04:23 PM
tanngo's Avatar
Foto de perfil auto
