Adaptive Control Dampening ???
Old Aug 27, 2011 | 11:36 AM
TxToast's Avatar
Default Adaptive Control Dampening ???
Looking at Parts Geek and the various Bilstein struts for the XK8. Two obvious "newbie" questions...
1) There are two front and three rear options. Any significant differences? How do I match up the "correct" model for my 2000XK8?
2) None have "Adaptive Control Dampening". Do I need it?
Thanks again for all of the combined knowledge & wisdom...hopefully in time I'll be able to contribute in some small way....
Old Aug 27, 2011 | 12:10 PM
Reverend Sam's Avatar
Pop your hood and look at the top of the shock towers. If there are wires coming out of the tops of the shocks, then you have the electric shocks. If you have no wires then you have the standard shocks.
Old Aug 27, 2011 | 05:10 PM
TxToast's Avatar
Old Aug 27, 2011 | 10:12 PM
H20boy's Avatar
get the cheapest one they have listed for Heavy Duty Bilsteins, parts geek may have multiple suppliers for the very same shock, and all are identical and will fit if listed for your car MY. Don't let the various parts numbers fool you, $92 each, don't pay more than $100 a piece.
Old Aug 28, 2011 | 05:42 AM
Skid Mark's Avatar
I didn't know XK8's had adaptive suspensions. Thought that was an XKR feature?
Old Aug 28, 2011 | 11:16 AM
Paul Pavlik's Avatar
I think that you could order it as an Option on a XK8.
Old Nov 15, 2014 | 03:02 PM
1walter1's Avatar
Two questions please. (1)I have a 2000 XKR with active damping control. Do I need to spend the extra $ or can I use the standard shocks?(2) If I use the standard shocks how do I or can I make the "SUSPENSION FAULT" warning light go away? Thanks for any sugestions.
Old Nov 15, 2014 | 03:13 PM
RJ237's Avatar
You would have to change all four shocks, then unplug the control module in the trunk. I asked the same question a month or so ago. Unless you really need the stiffer ride in sport mode they are not necessary.
When you have time, please visit the new member area and introduce yourself.
https://www.jaguarforums.com/forum/n...-intro-must-5/
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
zdrapec
Sep 25, 2015 05:49 AM
