Air cond. code 24
Old Nov 24, 2014 | 10:47 AM
TreVoRTasmin's Avatar
Default Air cond. code 24
My AC isn't working. Here is the short. Hit a deer in June, got the damage fixed the ac was working prior but you could tell the clutch was starting to slip. Got it back from the body shop and the clutch had seized, replaced the compressor and drier and had it filled when it was in getting the motor mounts done. Today it is warm enough for it to come on and noda. Checked the codes it is showing a code 24 which is 24 Face vent demand potentiometer fault Potentiometer open / short circuit Harness / connector
fault Refer to PDU
The low side is showing 110 with the compressor off.
Thoughts out there. Not real good on ac myself.
Old Nov 24, 2014 | 11:10 AM
Gus's Avatar
Gus
Did you clear the code to see if it comes back?
Old Nov 24, 2014 | 11:14 AM
Gus's Avatar
Gus
I recently did a lot of work on my A/C system Give us the readings on both the high and low side.
Old Nov 24, 2014 | 11:29 AM
I cleared it, will see if it comes back. I don't think the compressor is turning on. Don't have any way to measure high side but low side is about 110psi (hence why I don't think the compressor is turning on.
Old Nov 24, 2014 | 11:33 AM
Gus's Avatar
Gus
Have you checked the fuse and the plug to the compressor? Check your PM.
Old Nov 24, 2014 | 01:49 PM
Not yet, I had shoulder surgery 4 weeks ago so I'm in no shape to crawl under. As for the fuse. Haven't checked into that side yet as I need to figure out which one and where. Got your pm, will give you a shout tomorrow unless the number is good for evenings as well. Gotta get to a parent teacher conference in a few minutes.
Old Nov 24, 2014 | 09:15 PM
Gus's Avatar
Gus
I got this in my PM
Hey Gus,
found the fuse and sure enough it was popped. Good to go, low side pressure dropped to 25psi and ran good. Thanks again for your help.
philwarner
Oct 4, 2024 01:37 PM
cissdm
May 3, 2016 06:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
