Air leak after valley hose change
Old Apr 3, 2025 | 12:28 AM
pcolapacker's Avatar
Default Air leak after valley hose change
Recent thread about changing all heater hoses. Today checking with black light (UV dye in coolant) for any coolant leaks. No coolant, but just a little bit of oil in left side (American driver's side) of valley. Just a couple drops. Sprayed some starter fluid and affects engine. More effect when spray on left side than right side. Long term fuel trim bank 1, 19.5% and bank 2, 14.8%. Both short terms hovering around zero. No check engine light. Have driven a few hundred miles since hose replacement.
I used new manifold seals and cleaned the surfaces. Wondering if could be breather hose (if that's what you call it) running under manifold to left driver's valve cover.
Old Apr 3, 2025 | 03:23 AM
bladerunner919's Avatar
Yes, could be - they get very crispy.
Old Apr 3, 2025 | 06:37 AM
RJ237's Avatar
Also, the accordion section of the air intake pipe is subject to cracking.
Old Apr 3, 2025 | 11:17 AM
That was cracked when I bought her. Wrapped with high temperature electrical tape.
Old Apr 3, 2025 | 11:18 AM
Made of unicorn tears.
Old Apr 3, 2025 | 11:42 AM
Watched fuel trims as drove to work today. Cruising at 75 mph long term bank 1 at 0.8 and long tern bank 2 at 1.6. Readings above were at idle. Am I correct that excess air getting in has less effect at more throttle? Planning on leaving tomorrow with her on a 1000 mile round trip. Any concerns?
Moss shows this diagram with three parts but only one part listed for sale.  I called them.  The helper couldn't tell me which of the three parts I'd be buying.  Special order so 4 to 8 weeks for delivery.
Parts Geek has this one.  One connection is rubber hose in lieu of clip in.
Old Apr 3, 2025 | 12:10 PM
If mine needs replacing again it will be with rubber hoses between the plastic connectors.
Old Apr 3, 2025 | 12:33 PM
RJ237's Avatar
You should not have a problem on a trip. When LTFT gets to 25 you may have restricted performance, but at 2000+ rpm that's unlikely.
Old Apr 4, 2025 | 07:27 PM
2500DollarXKR's Avatar
I replaced the part load breather hose with 3/8" silicone vacuum line and it worked great.
Psycom
Sep 21, 2024 10:09 AM
miami jags
Nov 24, 2022 03:09 PM
mark campbell
Apr 21, 2017 12:52 PM
oyster
Nov 6, 2014 03:49 PM
YYC guy
Jun 27, 2014 07:47 AM
