Airbag dash warning / Code B2290 / B2291
Old Jul 30, 2023 | 09:47 PM
JaguarXKR's Avatar
Default Airbag dash warning / Code B2290 / B2291
Hi All,
My XKR has thrown two airbag code lights. Not sure if its battery related or if there is a problem.
What should I check first?
Thanks!
Old Aug 8, 2023 | 05:57 AM
PKWise's Avatar
It's unusual to have 2 Airbag warnings together. It will take some searching to find the common link.
I believe your 2001 car predates the Flash Code system introduced in late 2002. However, the attached document does have the Flash Code and relevant DTC codes listed. I hope it helps.
File Type: pdf
Old Aug 8, 2023 | 08:49 AM
motorcarman's Avatar
Info for you. (ARTS)
File Type: pdf
Old Aug 9, 2023 | 06:11 AM
JaguarXKR's Avatar
If I am reading this correctly, the one common point between the two codes is battery related.
The fault wasn't there when I parked the vehicle. Sat for about a year (on a trickle charger) and showed up on the first start.
Smonop
Aug 19, 2024 10:46 AM
chazaroo
Aug 9, 2013 05:06 PM
cmccutcheon
May 18, 2013 02:46 AM
Jon89
Apr 6, 2012 01:34 PM
Bowmanconsult
Oct 27, 2009 04:22 PM
