airbag warning light
Old Mar 31, 2021 | 09:38 AM
dneu's Avatar
Default airbag warning light
Hello, suddenly the airbag warning light came on in 1999 XK8. Three times it flashes the sequence 1-2 and then it stays on. Do you know what this code indicates? Thanks
Old Mar 31, 2021 | 12:38 PM
Johnken's Avatar
https://www.jaguarforums.com/forum/a...501-09-srs.pdf
Can you open this? Looks like all the codes.
John
Old Apr 1, 2021 | 07:48 AM
SamtheSham's Avatar
I had the same problem with my 2006 for the passenger air bag. Jag dealer said the problem was in wiring harness and could not be replaced. After staring at the light for several days of driving, a small piece of black tape, strategically placed over the light solved the problem.
Old Apr 1, 2021 | 08:24 AM
John
NO - the OP dneu is showing a 1999 XK8 which predates introduction of SRS (Supplementary Restraint System).
Old Apr 1, 2021 | 10:07 AM
dneu's Avatar
I opened the bulletin, but data do not correspond with my wiring diagram. I do not have a connectorCR 068
dneu
Feb 26, 2020 03:31 PM
RoyLittle0
Sep 17, 2018 05:09 PM
Timsjag
Aug 19, 2013 12:27 PM
chazaroo
Aug 9, 2013 05:06 PM
BLAIR250
Jul 1, 2007 09:54 AM
