Aircon code 23
Old Jun 26, 2012 | 01:57 PM
Gus's Avatar
Gus
If they put a set of gauges on it and the pressure readings are good I would be looking at the pressure switch. Just an FYI the pressure switch is often the problem. If the Freon is low then do what you need to do. Let us know how it goes.
Originally Posted by steveinfrance
No, I'm taking it in shortly. Hard to find a competent A/C shop in this neck of the woods but I think I have.
What they're threatening to do is a part fill with lots of dye, then I go back after a few days and they check for leaks. Seems a bit odd but still...
Will post results and costs!
Old Jun 26, 2012 | 07:02 PM
Gus's Avatar
Gus
Well did you get it fixed????
Old Jun 26, 2012 | 07:17 PM
The Coupe's Avatar
Gus, do you know if the pressure switch on a 1997 can be removed without discharging the system...a schrader valve in place, perhaps? I've got a bad pressure switch (thanks to some diagnostics by WhiteXKR and SteveinFrance), but I don't know if it's something I can replace myself or not.
Let me know what you think, if you please.
Old Jun 26, 2012 | 07:26 PM
He's in France Gus, "shortly" may not mean today.
Old Jun 26, 2012 | 08:09 PM
Gus's Avatar
Gus
I saw that he was on another tread of the same nature and it was the pressure switch and had hopes that his problem was the same.
Old Jun 27, 2012 | 02:42 AM
steveinfrance's Avatar
My problem's not the switch, if I jumper the clutch I don't get cold air.
Going on Saturday for the diagnosis.
Always amused by the US use of 'presently' I'll do it presently means 'immediately' in the US, or 'when it suits me' in the UK.
As Norri says, I'll do it presently!
Old Jun 27, 2012 | 07:16 AM
Today's Wednesday and going on Saturday for the diagnosis. That's counts as indecent haste in the Dordogne.
Old Jun 27, 2012 | 07:18 AM
  #28
Gus's Avatar
Gus
OK!
Old Jul 2, 2012 | 12:38 PM
FIXED!!!
It was the Schrader type fill valve.
A little 'family firm' Feu Vert (a bit like the Petit Casino franchise) had it for a couple of hours (of which half was telling the mechanics what HP, 0-100 km times etc) and found the valve was shot. They replaced it, refilled, left it an hour and rechecked and reckon that's the problem. €69 including the valve. Fingers crossed chaps !!
Old Jul 2, 2012 | 12:41 PM
  #30
The Coupe's Avatar
Excellent, a good result.
My beloved is with the techs today, and hopefully I'll have cold air blowing soon. I fear it won't be anything as simple as a bad schrader valve, however.
Old Jul 2, 2012 | 02:26 PM
  #31
Red1bw's Avatar
Hopefully that's it. I've had small leaks before where it takes about one week to lose enough refrigerant to be noticeable. Also, make sure your schrader valve caps are tightly on. Thanks for the shortly update.
Old Jul 2, 2012 | 02:55 PM
  #32
Well at the moment I'm a happy bunny but being a miserable old sod I expect it will have gone **** up in a day or two.
Old Feb 2, 2025 | 03:43 PM
  #33
BLKLSTD's Avatar
Default Adding refrigerant
Originally Posted by Red1bw
Yes....for a short time. However, another way to check that is simply to add a bottle of refrigerant. That should make the pressure rise. And if you are going to add a bottle of refrigerant, you might as well add a bottle of refrigerant with dye (as they are the same price as refrigerant without dye). And if you are doing that, you should spend about $10 at amazon or wherever for a UV light.
Every time I've had an AC issue on any car it has always been a leak. As a side result of the leak, you get low pressure, which prevents the compressor from running and hurting itself. Incidentally, you an also buy a vacuum pump on amazon for about $100 (to suck all the air out / evacuate the system).
When you do jumper it, once you hear the AC clutch engage then you know the problem and should then un-jumper it. By jumping it now, you can get your answer immediately without having to buy anything.
I realize this is an old post. But it's still out there. And people are reading it. It's not a good idea to just add refrigerant without knowing it's needed. Having too much will cause problems also. It can even cause damage or injury. The better thing to do if you don't have gauges to check the pressure would be to jumper the pressure switch as the OP suggested.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
rgp
Sep 24, 2015 05:04 AM
al_roethlisberger
Sep 21, 2015 08:15 PM
roby
Sep 20, 2015 01:54 PM
