Alarm Key Fob not working
Old Jan 1, 2013 | 02:37 PM
Charlie Galea's Avatar
Exclamation Alarm Key Fob not working
Hello and happy new year to all at this forum. My new year started with a small problem with the alarm fob of my XK8. basically its not working and the spare one I got is not working as well. I changed the batrries and cleaned the fobs but still nothing. The car alarm system works ok when I use it manually ie when I close the car with the car key. I have tried to follow the instructions in the fob programming tread of this forum but I cannot get the alarm to go into learning mode. Any suggestions?? and can someone tell me why this should happen? The only thing that I can think of is that I have not used the car for a month and 2 days ago I had to jump start it with all the usual reprogramming that goes with it.
Old Jan 1, 2013 | 02:44 PM
WhiteXKR's Avatar
The jump start may put the security computer in an unhappy state, and your battery may be low on charge.
First you need to charge the battery with a charger or take a long 1 hour plus drive to do the same.
Then try disconnecting the battery for 30 seconds and reconnecting it. If it does not work the first time, repeat it a few times, trying it after each one.
Old Jan 1, 2013 | 04:18 PM
NikasilNik's Avatar
Something I have noticed with my car ................... if I don't use the car for a week or so when I come to unlock her the fob's don't work , if I press the boot/trunk button or the headlamp button they work fine , after operating either of these the lock and unlock buttons work fine even from a large distance
It's as if the cars security module needs to be "woken up" and the only way to achieve this is to press the headlamp or boot/trunk button first, any idea's on this one WhiteXKR ,
Happy New Year
NikasilNik
Old Jan 1, 2013 | 06:44 PM
WhiteXKR's Avatar
Happy New Year
NikasilNik
Nik-
The car is supposed to go into 'deep sleep' and require the key to reactivate, but after 28 days. Maybe yours has a fast metabolism.
Old Jan 2, 2013 | 01:28 PM
Did all the charging and reprograming and although I can get the alarm into learning mode, I get the red LED light and the low chirp and when I press the key fob buttons nothing happens after a few seconds I get 2 car alarm chirps and that's it. The batteries are new and all is clean. i also try my spare key fob but still nothing. How do you test if the key fobs are transmitting???? Thanks to all
Old Jan 2, 2013 | 05:55 PM
NikasilNik's Avatar
Originally Posted by WhiteXKR
Nik-
A bit like myself
Happy New Year
NikasilNik
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Sprayall
Sep 3, 2015 07:49 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
