All warning lights stay illuminated???
Old Apr 18, 2013 | 12:43 PM
XK8-Brian's Avatar
Default All warning lights stay illuminated???
Hi Guys
I have a 1998 XK8 UK right-hand drive model. I recently had water ingress in the drivers foot well, this I discovered was seeping in under the rain gutter above the drivers door then running down the 'A' pillar, behind the plastic kick plate and onto the floor, this has been resolved. That has left me with an even bigger problem which must be linked as it wasn't there before the leak. With the ignition off both the red warning lights for the oil and temp stay illuminated, when the ignition is turned on all the warning lights illuminate and stay illuminated, there is no reading on the LCD display, the fuel gage does not move. When I start the car I have no rev counter either. I assume that something has got wet and shorted out, but where do I start? All the cables behind the kick plate within the drivers foot well are dry but they may have been wet when the water was leaking in. Is this a blown ECU? Any help you can give will be much appreciated.
Old Apr 18, 2013 | 03:02 PM
Any chance the water found its way along the harness to the Instrument Pack?
The right hand harness connection leads in from where you've had water ingress.
Old Apr 18, 2013 | 03:53 PM
RJ237's Avatar
Welcome to the forum, Brian. When you have time, please visit the new member area and introduce yourself. Just click on the link below:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Take a look at the ECU and see if there was water there, but I would agree with Graham that the instrument pack or one or more of the connectors to it are at fault. Fortunately, there are rebuild services for that.
Old Apr 18, 2013 | 04:20 PM
XK8-Brian's Avatar
Thanks guys, I have checked in and around the ECU but the recess and all that area under the bonnet in bone dry. I had assumed that water would have got to these connectors in the foot well, I have had the ignition on and disconnected all these connectors but the lights stay on, at the driver side end of the dash there is fuse box and one brown relay if I remove this relay the lights in the main pod extinguish but the two red ones (temp and oil) stay on. One thing I forgot to mention was that I have an err displayed on the climate control display along with a beep which is related as that was not there either! Is there anything under the carpet that is connected to the dash or ECU?
Old Apr 18, 2013 | 09:17 PM
WhiteXKR's Avatar
Brian...see if fuse 14 in the driver side fuesbox is blown.
If that is OK, try disconnecting the battery for a munute and then reconnect it. You will need to then reset your windows and enter your radio code (as per the owners manual).
If still no luck, your next step I think to to remove the instrument cluster and inspect it for water.
Old Apr 23, 2013 | 01:34 PM
XK8-Brian's Avatar
Default A big Thanks Guys
Thanks to you who replied and tried to be of assistance, I have resolved the issue of the warning lights, I replaced the complete major instrument cluster with a known good one and hey presto all works I am however left with a mileage showing nearly twice as much as the car has genuinely done, is there a way to calibrate to the original mileage or get the old cluster repaired?
Thanks again guys
Old Jul 9, 2024 | 06:15 PM
captainobvious1's Avatar
I am having the entire instrument cluster replaced myself. Everything went wonky, and nothing reads right. I am adding another 10,000 miles to the clock, but I'll be able to read everything again. the original is FUBAR. (There's no saving this one).
Old Jul 12, 2024 | 04:09 PM
I await the arrival of my Instrument Cluster so that i don't have to guess the status of my XK8's systems. It is truly a lonely vigil.
Old Jul 13, 2024 | 03:39 AM
dibbit's Avatar
It is possible to swap the processor from the old cluster to the new one to retain the original mileage, or do a mileage correction on the new cluster. Interesting video on what's involved here:-
Old Jul 15, 2024 | 06:06 PM
I sent a copy of "cloning the XK8's instrument cluster" to my Portland, Oregon area Jaguar repair shop (Consolidated Auto Works 1641 SW Multnomah, Portland, OR). they were happy to get it. My instrument cluster should arrive on July 18th so that may have my XK8 repaired quickly.
Old Aug 9, 2024 | 05:29 PM
Default Well...
I ordered a replacement Instrument Cluster 9using my VIN and part number (LJD4300HC) so that I won't get a non-functioning part (again). It should be here August 12th and repairs effected by the end of business day, August 13th.
Wish me luck.
Old Aug 12, 2024 | 05:23 PM
My Instrument Cluster arrived @ Consolidated Auto Parts. We'll see how this play out.
Old Aug 13, 2024 | 05:39 PM
Installed the Instrument cluster. It has more than 173000 miles on the clock and the headlight indicator doesn't light. Aside from that, I'm back in business.
Old Aug 24, 2024 | 02:23 PM
stevis05's Avatar
Was reading this thread and it dawned on me that if you swap the whole instrument cluster, it will then display the mileage of the original car it came from, and based on everyone’s input it’s usually higher than their original mileage of the car it’s going into… thus getting me to wonder if it also works the other way around? Meaning for example if a car has 170,000 k miles on it and you swap in a cluster from a car that had say 110,000k mi, would your car now display the 110,000? I don’t know if anyone has that exact answer but I am curious
Old Aug 24, 2024 | 03:31 PM
I'm afraid the original car's mileage is what I will have. Yes, the odometer will have the mileage from the donor car.
JaguarXJL15
May 14, 2024 11:53 AM
DUNKS
Dec 1, 2022 11:02 AM
AndyfromRhodeIsland
Feb 8, 2020 12:24 AM
Pepper
Aug 11, 2019 01:30 AM
Qvhk
Jul 29, 2019 12:33 AM
