alum coolant dist pipe?
Old Aug 29, 2013 | 03:29 PM
sharay38's Avatar
Default alum coolant dist pipe?
I'll be having the tensioners replaced in the next couple weeks, and decided to replace the thermostat, housing and coolant at the same time. I have parts on order, but could not find an aluminum coolant distribution pipe. I found the question dated earlier in this forum, but never the answer. Now would be the best time, if one is available. Otherwise...
Old Aug 29, 2013 | 04:31 PM
DaveC's Avatar
I don't think anyone makes one or at least I haven't seen it. When I had the Tstat tower done the mechanic replaced the distribution pipe with OEM.
Old Aug 29, 2013 | 07:17 PM
An 'aluminium coolant distribution pipe'......
I recall a post about replacing the plastic and rubber bleed hose (item 7) from the Thermostat Tower to the Expansion Tank with metal.
Is this the one you mean?
Old Aug 29, 2013 | 10:32 PM
DaveC's Avatar
I thought it was the plastic pipe that run in front of the t-stat tower. Funny, I just replaced the part you noted last week. Broke it when I was cleaning the engine. It was amazing how flexible the new part was.
Poet
Feb 7, 2025 02:18 PM
vwbusbits
Oct 13, 2015 03:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
hoodun
Sep 28, 2015 01:08 AM
