amber check engine light 2001 XKR
Old Apr 15, 2016 | 02:40 PM
jim graham4300's Avatar
Default amber check engine light 2001 XKR
Hello,
My 2001 XKR is displaying an amber colored check engine light. Any thoughts will be appreciated.
Thank you,
Jim
Old Apr 15, 2016 | 02:46 PM
DandyAndy's Avatar
Hi Jim,
you need to use an inexpensive OBDII reader to read the fault codes. If you don't have one, go to one of the chain auto parts stores who normally will read the fault codes for free.
Old Apr 15, 2016 | 05:21 PM
....... then post the actual CODE (or codes) back here - not what anyone tells you it means.
The definitions in generic code lookups can often be misleading with Jaguars.
Old Apr 21, 2016 | 03:11 PM
Thank you. Problem was a bad cap for the gas tank ,,, not sealing properly. Replaced the cap and all is now good.
Traindriver69
May 11, 2021 03:04 AM
Philly Single
Jul 17, 2017 03:53 PM
Jack Mathews
General Tech Help
May 28, 2016 11:34 AM
80sRule
Apr 19, 2016 11:53 AM
boomerang
Apr 9, 2016 11:37 AM
