another timing chain tensioner question
Old Jan 28, 2013 | 08:30 PM
WhiteXKR's Avatar
Originally Posted by giandanielxk8
$20 less than the Jaguar dealer tensioners or less than what Roger linked to?
I noticed you only gave me the part numbers for the secondary tensioners, what about the primary ones? Should I also change those?
If you are on a tight budget just do the secondaries...they are the ones that can cause serious damage if they fail.
The primaries are a much bigger, more complex job, plus they will likely make plenty of noise as they fail.
Old Jan 29, 2013 | 05:08 AM
giandanielxk8's Avatar
Noise, what kinda noise are we talking about? Is it a whine or a rackety sprakety sorta noise?
Old Jan 29, 2013 | 06:26 AM
test point's Avatar
Sorta like a chain rattle.
Old Jan 29, 2013 | 07:27 AM
RJ237's Avatar
Changing the primaries is a much larger undertaking. You can inspect the sliders when doing the secondaries, and change if they are damaged. Consensus is that they will rattle if they begin to fail, but not cause catastrophic engine failure.
I didn't change mine and am not concerned at this time.
Old Jan 30, 2013 | 05:15 AM
Ok. Is it a loud rattle? I can sometimes hear a very faint rattle in my car, usually when I'm inspecting the engine with the hood up. I've always heard it, so I think it is normal...
Old Jan 31, 2013 | 07:10 PM
'00XK8's Avatar
i wish i had known about the ford tensioners......i already bought the jag tensioners.
Old Jan 31, 2013 | 09:31 PM
That's the beauty of being a college student on a budget; you learn to research and find the least expensive alternative to what you're going to buy. From food to jag parts.
Old Nov 25, 2015 | 09:21 AM
  #28
Flyboygus's Avatar
If you are on a budget, I highly recommend Christopher's Foreign Car Parts. He has the complete package with everything you need and it is cheaper than trying to find all the parts on Ebay, Amazon, etc.
In addition, you can rent the special tools you need.
I found his service, including handling returns, to be outstanding. IMHO
Old Nov 25, 2015 | 12:14 PM
xk8lattmaster's Avatar
I was quoted $199.00 for the Ford tensioners with the bolts.
Bought them on E-bay for $119.00 with bolts and chains.
Installed them, engine purrs like a kitten.
Old Jun 2, 2020 | 06:44 PM
  #30
Syb Drylst's Avatar
@Jacsun - it seems like $600 was a bargain. ive read where this is usually at least a $1000-$1500 job.
Yes, I did mine and cost $ 2300 cdn, wondering what did they do for $600.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
