Antenna Maintenance
Old Oct 31, 2010 | 10:29 AM
JagYour's Avatar
Default Antenna Maintenance
Can anyone recommend a good cleaner or lubricator to apply to my aerial? The manual says to use a jaguar approved cleaner and to wipe upwards and that is it. Can anything else be used? WD40 or grease or other?
Old Oct 31, 2010 | 10:54 AM
Reverend Sam's Avatar
Just use a silicone lubricant. I cant think of any brand names at the moment, but the lubricants section at any hardware store or home center will have some.
Old Oct 31, 2010 | 10:58 AM
Gus's Avatar
Gus
Spray it with WD40 work it around the antenna operate the antenna and wipe it dry then do it again for 3 to 4 times. If your antenna is not broken internally this process will help in making it operate smoothly and consistently. Keeping it clean and dry is what you want to do. WD40 stands for water-displacing and the 40 means it took 40 attempts to create. In your case you need to keep it clean from dirt and the spray will do the rest
oldjaglover
Dec 25, 2024 04:33 PM
philwarner
Jan 31, 2016 09:36 AM
wonderwire
Oct 4, 2015 05:41 PM
reb1999
Sep 26, 2015 08:41 AM
