Antenna Motor Removal Question
Old Sep 5, 2010 | 09:34 PM
scottatl's Avatar
Default Antenna Motor Removal Question
I need to remove the motor, the plastic belt busted off inside of it. Seems like you need to remove the metal changer/amp housing rack first. I got off the 2 bolts you could see from the rack and was hoping that was it, but there is a third bolt I can not get to. Any ideas?
Attached Thumbnails Antenna Motor Removal Question-dsc08039.jpg   Antenna Motor Removal Question-dsc08040.jpg   Antenna Motor Removal Question-dsc08041.jpg
Old Sep 6, 2010 | 01:37 PM
SeismicGuy's Avatar
I looked in the JTIS under antenna motor removal and there was nothing said about the need to remove the accessory rack.
Doug
Old Sep 6, 2010 | 05:14 PM
hlgeorge's Avatar
I had to do the exact same thing on my XKR. I did not have to remove anything to get it out, but it was not an easy procedure to do. I even have the taller rack. As you can see, it was pretty mutilated.
I see your hydraulic pump motor hoses look new. Have you replaced them recently?
Old Sep 6, 2010 | 08:25 PM
scottatl's Avatar
Yes, I did replace them with the aftermarket hoses recomended in the FAQs.
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
