Antenna travel
Old Dec 20, 2012 | 07:22 AM
Rramshur's Avatar
Default Antenna travel
How is the antenna up/down travel adjusted?
I just had a local (non-Jag) shop install a replacement antenna it won't fully extend/retract.
Any clues?
Thanks.
Bob
Old Dec 20, 2012 | 07:30 AM
Gus's Avatar
Gus
Spray with a little WD40 and operate it several times then wipe off the residue and do it again and see if it improves the operation. When you are done remove the residue of the WD40 from the antenna mast.
Old Dec 20, 2012 | 11:14 AM
Jon89's Avatar
I believe that a dab of lithium-based white grease is a better lubricant for this particular application. I've used it for decades on all of our power antennas and never had a problem....
Old Dec 20, 2012 | 02:49 PM
Gus's Avatar
Gus
That may be true but the WD40 will clean the gunk that is preventing the full travel up and down.
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
philwarner
Jan 31, 2016 09:36 AM
Kaeghl
Sep 25, 2015 12:49 PM
