ASC fail, restricted performance
Old Mar 29, 2016 | 03:40 PM
drdan7's Avatar
Default ASC fail, restricted performance
My '99 XK8 convertible will go into restricted performance and flash ASC upon reaching highway speeds (60-70 mph). It resumes normal performance when I switch off ASC and seems to perform responsively. The only other issue I have is, if she sits for about three days, the battery needs recharged. This started before the TB rebuild. She's got about 66,000 miles and just had TB rebuild (outstanding job by ASI). Any ideas?
Old Mar 29, 2016 | 03:53 PM
Jon89's Avatar
These cars despise weak batteries and will throw all sorts of spurious codes and messages once the battery begins to fail. First things first - sounds like you need a new battery....
Old Mar 29, 2016 | 08:25 PM
brgjag's Avatar
put a battery in it. That prob will fix the issues. I have to pause and wonder if the TB rebld was needed is you have such a weak battery?
Old Mar 30, 2016 | 08:21 AM
drdan7's Avatar
I kind of thought the battery might be the main issue. I had read some other threads re: unrelated codes and my any people blamed the battery. I'll get it checked out ASAP.
Old Mar 30, 2016 | 08:24 AM
drdan7's Avatar
Except for the issues I listed, the car has run remarkably well since the rebuild, before it would go into limp home mode about every 10 miles. But, I will be getting a new battery this week. Thanks.
bjmawg
Aug 26, 2021 07:59 AM
BillC
Mar 16, 2016 09:37 AM
Ragsdale
Mar 14, 2016 09:25 PM
newbee
Mar 8, 2016 01:14 PM
brinny
Mar 7, 2016 04:45 PM
