ASC and TRAC not available ABS light on
Old Aug 28, 2014 | 01:30 PM
Old_Doc's Avatar
Default ASC and TRAC not available ABS light on
Took XK8 to local shop the get AC charged. As I drove away saw the ABS warning light was on and the message ASC NOT AVAILABLE and TRAC NOT AVAILABLE. Can anyone point me to potential problem
Old Aug 28, 2014 | 02:36 PM
RJ237's Avatar
This is a very common complaint, with many possible causes. The best way to handle it would be to have the codes read by a dealer or independent with Jag specific test capability. If you want to try to solve it on your own, the following is a starting point:
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Old Aug 29, 2014 | 07:20 AM
Old_Doc's Avatar
Default Time to order a new control unit?
The problem went away. I'm going to clean wheel sensors but based on posts found here I'm probable going to need a new ABS control unit.
Old Aug 29, 2014 | 08:42 AM
batroute's Avatar
Make sure your battery is fully charged and in good condition- a failing battery can trigger all sorts of fault codes and messages.
Old Aug 29, 2014 | 08:51 AM
RJ237's Avatar
If it is faulty, the problem is often the solder connection to the abs pump, code C1095. A new abs module is several thousand dollars, while having yours repaired is under $100.
At this point you may want to consider having the codes read so you can make the proper decision. It may be nothing more than a failing wheel sensor cable or the pump connection.
Old Aug 29, 2014 | 01:42 PM
sharay38's Avatar
I'm not dismissing all the fine suggestions you've already received. I had the same issue, hit, even a small bump, and the ASC and Trac Control, as well as "fail safe" mode, with reduced performance would ensue. OBD codes indicated throttle position sensor, and mass air flow sensor. While still in the process of investigating the OBD issues, I cleaned the wheel sensors. Simply cleaning the sensors ended all other issues immediately. In fact, even the OBD computer reset on its own, and the Check engine light went out, after about a week. It's now been over a month, and there hasn't been a recurrence of any kind. So, if it were me, I'd clean the wheel sensors first, and then address any issues that remain. Good luck!!
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
innzane
Sep 2, 2015 10:08 AM
