Auto Dimming Rearview Mirror Replacement
Old Oct 29, 2011 | 12:17 PM
  #61
avt007's Avatar
That's the plug for the microphone if you have a phone installed.
Old Nov 9, 2011 | 10:31 AM
  #62
jagjoe's Avatar
Default jagjoe
Called Sybesta and was told they do not repair the mirrors that have a slide type installation, only the push button style. Unfortunatly I have a slide style. Anyone have another repair shop that will do the repair?
Old Nov 24, 2011 | 11:47 AM
  #63
DJagman's Avatar
Thumbs up
Well, this stinks. I put the car in the garage last night and everything was fine. Go out today to go to the store and I have a oval circle in my mirror just like the picture in the first post in this thread. Now I get to explore the adventure of getting my old mirror off and a new one back on. I really want to thank everyone for all of the information in this thread and the forum in general. It makes all of these unique things that make these cars so special, but at the same time add a degree of complexity to them, a lot easier to deal with.
Many, many thanks. It is Thanksgiving day after all.
Old Nov 24, 2011 | 03:17 PM
  #64
MRomanik's Avatar
Veteran: Air Force
Noticed my mirror was loose and pushed back up. I will have to check to see if I need to replace as well.
Thanks to all.
Old Dec 26, 2011 | 04:30 PM
  #65
kvmentor's Avatar
Originally Posted by K.Westra
Ok, so I've been extremely slow on this, but I finally pulled my mirror and got the information to send for a replacement mirror.
One note, if your car is equipped with the rain sensing wiper option, I recommend removing the bottom plastic cover so that when the mirror is removed, the second plug can be easily removed.
Here is what the mount and plugs look like on my 2000 XK8 equipped with automatic headlights and rain sensing wipers.
This is the mount and the sensor for the rain sensing wipers:
This is the connector on the roof that the mirror plugs into:
Here is the back attachment on my mirror (which is the same mount as Gordo's) which also shows the additional plug for the rain sensor:
How did you pry off the the little grey or black plug connected to the rain sensor? Mine is starting to separate (top of the plug).
Old Dec 26, 2011 | 07:33 PM
  #66
K.Westra's Avatar
It's been a while since I did it, but I think the little piece on the right that sticks out of the rectangle needs to be pushed in to release a little clip.
Old Dec 26, 2011 | 10:47 PM
  #67
kvmentor's Avatar
Thanks Keith. I did get the little plug out but the problem was it was broken at the ridge line. I super glued it and hope it stays together.
Old Dec 27, 2011 | 06:28 AM
  #68
doc18015's Avatar
Suppose one does not want the auto-dimming function.....I read that a Dremel does away w/it. How is it done??
Old Dec 27, 2011 | 08:46 AM
  #69
WhiteXKR's Avatar
Not certain on a '97, but on mine there is an on/off switch at the bottom center of the mirror and a level adjust at the bottom rear.
Old Dec 27, 2011 | 02:52 PM
  #70
K.Westra's Avatar
Same on my '00. Just push the bottom button and the light turns off.
Old Dec 27, 2011 | 05:00 PM
  #71
doc18015's Avatar
Thanks but i was thinking of draining the nasty fluid.....how is it done ?
Old Dec 27, 2011 | 05:12 PM
  #72
jagjoe's Avatar
I gave up looking for a reasonable cost solution, removed the auto mirror, bought a 8" manual day/night mirror, glued a new mount on the windshield, installed the new mirror and for $14.00 no one knows the difference. When I drive at night it is very easy to flip the dimming lever and I saved $400
Old Jan 9, 2012 | 03:29 PM
  #73
MrTrouble1K's Avatar
Hey all, my mirror went quite some time ago, so I just turned the auto-dim off. The oval in the middle has gotten to the point that I distorts the image terribly. I went to the scrap yard and pulled one off an XJ that was there and nearly complete if you can believe that. Now, the new mirror has a plug for the rain sensing wipers and my car doesn't have them. My old mirror has 4 or 5 wires and the new one has 8 or 9. Also, my old mirror has a brown wire and the new one doesn't. I figured I would just cut the connector from the old mirror and solder it onto the new mirror's wiring. Anyone know which wires I need to keep if there is a black wire on the new and brown wire on the old?
Old Feb 3, 2012 | 11:36 AM
  #74
cstu's Avatar
Just bought a 97 XJR and of course it needs a new mirror? Any problems with getting it done?
Old Feb 3, 2012 | 12:58 PM
  #75
GordoCatCar's Avatar
No problems for most owners who can perform simple maintenance jobs. Read the beginning of this thread for DIY instructions.
Old Feb 5, 2012 | 10:46 AM
  #76
ezeddie's Avatar
Default A BIG Thank You
I just found that the RV mirror on 98 XK bit the dust. My hope has arisen after finding the article on the replacement from Sybesma's, however I'm not all that comfortable with the removal and installation. Is this best left to a Jag dealer or windshield installer?
WELCOMEto tronics
Old Feb 9, 2012 | 02:40 PM
  #77
ezeddie's Avatar
After reading the many articles, and the detailed procedure posted by GordoCat, I opted for the safe way and went to the local Jag dealer. Interesting, they wouldn't tackle the job, but suggested "their glass installer". He came today and was unable to do the job. Said he would do more research and call back...I don't have a warm fuzzy feeling that I'll hear back. I did have feeling that I might be able to do the job, looks like I will.
Old Mar 29, 2012 | 03:38 PM
  #78
CrazyIvan1958's Avatar
My '98 XJ8L mirror is shot in this same way...and additionally does not stay attached to the windshield. The clip is there, but there is no connection to the center of the square peg on the windshield to hold it in place.
When these folks refurb the mirror, does that get fixed as well??
Old Mar 29, 2012 | 04:20 PM
  #79
NikasilNik's Avatar
Thanks for the excellent write up , I'll just be careful when and if I have to remove mine ,
I retrofitted photo chromic door mirror glasses to mine recently after retrofitting powerfolds , for information , they are "plug n play" and work perfectly ,
Nik
Old Mar 29, 2012 | 06:55 PM
  #80
stevepaa's Avatar
Same thing on my 2001 Volvo XC70. It is my wife's daily car and I did not know about the repair. So I bought a manual dim from a junker and put it in. I'll send the auto dim off for repair now.
