backseat removal
Old Feb 8, 2015 | 02:38 PM
cork's Avatar
Default backseat removal
I need to remove backseat bottom cushion, can someone walk me through the steps? Thank you.
Old Feb 8, 2015 | 04:25 PM
RJ237's Avatar
Hardly steps. Just under the edge of the cushion find two nuts. Remove and pull the cushion out, feeding the seatbelts through the boot, which has a snap. That's assuming you have a XK8
When you have time, please visit the new member area and introduce yourself. Also, use the USER CP at the top left of the forum page to add your signature and yr/model to your messages.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 8, 2015 | 04:27 PM
ccfulton's Avatar
Remove the two 10mm nuts at either side, under the front edge of the cushion. They are normally covered with a rubber cap that must be removed first.
Lift.
That's about it.
If you need to take it out of the car completely, you will have undo the center bolt that holds the seatbelts. It's a big torx, T24 sticks in my head but I'm not positive.
Old Feb 8, 2015 | 06:32 PM
RJ237's Avatar
My 97 conv. has a boot that the belts slide out of, no need to remove the bolt. Your coupe must be a different configuration.
Old Feb 9, 2015 | 01:25 PM
aardvark64's Avatar
My 99 XKR coupe has a leather boot around the seat belts. The boot has metal ('popper') studs that can take a bit of opening. Once they're open, seat belts feed through the boot when you pull the cushion out. I found the studs quite hard to open first time, but easier subsequently.
Hope this helps.
Best wishes, Colin
Old Feb 9, 2015 | 09:01 PM
ccfulton's Avatar
You know what, you are absolutely right.
I thought it was two loops of leather, one around each buckle, but there is indeed a snap in the middle.
Silly me for unbolting it.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
