Bad ECM ???
Old Jan 11, 2017 | 08:31 PM
brian2001's Avatar
Default Bad ECM ???
The past 3 weeks I been trouble shooting and reading many threads for my 2001 XK8 (109K miles) error codes P0300, P0302, P0303, P0304, P1316, PO353, P1111. With all the misfires I replaced the plugs didn't help. I moved the coils from one bank to the other same codes. I replaced the fuel injectors didn't help, the fuel pressure is good. I was going to test the cam position sensor, but I had both disconnected I decided to try to start the engine and it started. I thought if the cps is unhooked the engine wouldn't start. Before I go any further I'm asking for any suggestions. Timing, ECM, other sensors ???
Last edited by GGG; Jan 12, 2017 at 10:27 AM. Reason: Edit 'EMC' to 'ECM' in thread title
Old Jan 11, 2017 | 09:19 PM
chillyphilly's Avatar
How old is your battery and does it hold a charge?
Old Jan 11, 2017 | 09:34 PM
brian2001's Avatar
the battery is 2-3 years old and I had the charger on over night last weekend
Old Jan 11, 2017 | 10:45 PM
WhiteXKR's Avatar
Is it idling rough? If so, it the cam sprocket on one bank could have jumped a tooth, especially if the secondary tensioners are not upgraded.
Old Jan 12, 2017 | 06:48 AM
brian2001's Avatar
Yes she idles rough. I replaced the secondary tensioners 4 years ago. If it jumped a tooth could you check the timing.
Old Jan 12, 2017 | 07:31 AM
RJ237's Avatar
Just pull the cam covers and rotate clockwise from the front with 24mm socket until the flats on the cams line up. If they don't, the timing is off.
Old Jan 12, 2017 | 07:01 PM
brian2001's Avatar
I took both cam covers off and all cams are level on the flat part. All the chains are snug. It was nice to see how clean everything was.
Old Jan 13, 2017 | 09:45 AM
brian2001's Avatar
What I posted at first I said I disconnected both cpm and the engine started. After I took the valve cover I found out they were CAM CAMSHAFT VALVE TIMING SOLENOID SENSOR. I found where the cps are. Could the cps be bad?
Old Jan 13, 2017 | 07:56 PM
RJ237's Avatar
Yes it could. A symptom of a bad cps is hard starting, but once it starts it runs okay. This doesn't seem to be your problem.
Old Jan 14, 2017 | 09:41 AM
brian2001's Avatar
I did test the OHMs on the knock and cam position sensors and they all pass. Why is the problem on one bank?
Old Jan 14, 2017 | 12:24 PM
RJ237's Avatar
If it were a AJ26 I'd say it was the ignition module for that bank, but yours should be a AJ27 and the ECM controls it. I don't think you could get the coils on the wrong cylinders, but a bad connection to the ECM like a bent pin could be at fault.
It might be a good idea to disconnect the ECM cable and look for corroded or bent pins. Disconnect the neg battery cable at the battery first and touch it to the pos. terminal to discharge the capacitors.
Old Jan 16, 2017 | 09:45 AM
brian2001's Avatar
I tried that with no success. The more I think about it is more of a fuel problem?
Old Jan 16, 2017 | 11:01 AM
RJ237's Avatar
I'm not sure why you suspect a fuel problem if you replaced the injectors and the pressure is good.
Old Jan 16, 2017 | 06:29 PM
brian2001's Avatar
because the problem is on the right bank. The last 3 cyl. have a misfire. It is at the end of the fuel rail
Old Jan 17, 2017 | 11:12 PM
Chuck Schexnayder's Avatar
brain2001:
Although my car is a 2005, see my thread just above yours under "Restrictive Performance".
Your problem is just like mine, except my misfire started out on #3 cly, but changed to #5 for some reason.
I'm removing my ECM at this time and sending it off for repair--if that's what it is.
Old Jan 24, 2017 | 01:21 PM
brian2001's Avatar
I'm still trouble shooting mine. Let me know of your progess
Old Jan 24, 2017 | 02:49 PM
Gus's Avatar
Gus
The face that you only have 3 of 4 cylinders misfiring and you changed the plugs and swapped the coil packs from side to another and you had replaced the fuel injectors I would be looking at the ECM. However, I would check the battery for proper voltage 12.2v minimum and the fuel pressure. I know if it were either one you should have the problem on the other side but it would be good to check it anyway. As for the chains and tensioners you should check the flats to be sure they line up on both sides. If all of that is good then pull the ECM and have it checked. ASI has a good reputation on making repairs to them.
Old Jan 24, 2017 | 07:24 PM
DAN L's Avatar
Default asi
for the few dollars that asi wil charge you to test your eem it is money well spent. and if it needs to be repaired you cant get a better place to do it . they did mine years ago and not one problem . great to deal with and great price . good luck Dan L
Old Jan 28, 2017 | 05:32 PM
brian2001's Avatar
Gus I have checked the battery, fuel pressure, cam timing all is good. I replaced injector, plugs, cps. When I test drive her she still idles rough but moving down the road she runs fine. I can step on it she takes off, after 4 or 6 time of that then I will get a RP. At different speeds she runs rough also. Who, where and how much $ ASI
Old Jan 28, 2017 | 07:31 PM
RJ237's Avatar
I believe testing is still about $55. Give them a call.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
