Bad shock towers in rear-2006 X8
Old May 30, 2016 | 12:32 PM
Salu498's Avatar
Default Bad shock towers in rear-2006 X8
What kind of cost am I looking at to replace bad shock towers on 2006 XK8 convertible?
Old May 30, 2016 | 02:13 PM
brgjag's Avatar
bad shock towers?? Can you be more specific? shocks? Bushings?
Old May 30, 2016 | 02:35 PM
Salu498's Avatar
That's what I was told, but I may have misunderstood? I think they said they were crumbling.
Old May 30, 2016 | 03:14 PM
RJ237's Avatar
They were referring to the shock mounts. They and the isolators fail eventually as they are a dense foam. The lower shock mounts should probably also be replaced while the shocks and springs are out.
The parts are not expensive, less than $200, I believe, but it could take up to ten hours depending on how they do it. I recall a procedure that cuts the time in half, and someone will probably be able to reference that for you.
Merv
Jun 12, 2016 12:35 AM
STRACAT
May 29, 2016 06:55 AM
2001 XKR
May 25, 2016 09:41 AM
terrylcook
May 20, 2016 03:29 PM
QTD
May 15, 2016 11:57 PM
