Bank one or two
Old 08-27-2018, 10:01 AM
jetjack's Avatar
Default Bank one or two
Hi all,
Just for reference, I'm guessing bank one is drivers side on US cars?
I'm replacing a knock sensor on bank 2
Thanks,
Jack
Old 08-27-2018, 10:50 AM
RJ237's Avatar
Received 2,786 Likes on 2,229 Posts
No, bank one is right or passenger side on LHD.
Old 08-27-2018, 01:29 PM
jetjack's Avatar
Well I had a 50/50 chance, thanks for the help
zray (08-29-2018)
Old 08-27-2018, 01:58 PM
fmertz's Avatar
Received 1,487 Likes on 1,043 Posts
Knock sensors require a bit of work to get to, so consider replacing both. And the old hoses under the manifold, too. And if you change both, the bank number does not matter anymore.
Old 08-27-2018, 02:40 PM
Received 7,899 Likes on 4,771 Posts
You can 'fish' both the KSs through the intake on the NA 4.0 engines.
The nut is 13mm and the M8 stud has an EXTERNAL TORX for removal.
bob
Old 08-27-2018, 05:56 PM
jetjack's Avatar
Thanks, I changed all the hoses last Winter and noted the the knock sensors could be replaced without removing the intake again.
Old 08-27-2018, 06:35 PM
GGG is offline
Received 16,822 Likes on 12,177 Posts
Originally Posted by jetjack
.... I'm guessing bank one is drivers side on US cars? ....
It's a Jaguar - nothing is that simple.
Attached are the various cylinder numbering "standards" Jaguar have used.
File Type: pdf
zray (08-29-2018)
etaent
08-30-2018 11:32 AM
Quick Reply: Bank one or two
