battery disconected
Old Apr 16, 2014 | 08:51 AM
magnum454's Avatar
Default battery disconected
Is there anything necessary to do when re-connecting the battery after doing some welding on the exhaust? 2000XK8 conv. Some things don't act the same as before, like the windows don't always go up to to align with the top when the doors are closed.
Old Apr 16, 2014 | 08:56 AM
test point's Avatar
The window memory will need to be reset. With the door closed, hold the 'down' switch for a few moments past reaching full down until you hear a 'click'. Low volume 'click'. Hold the 'up' switch for a few moments past full up until you hear the same click. Same for the other door.
Fuel trim will take a few miles to reset but other than that you are good to go.
Old Apr 16, 2014 | 09:11 AM
magnum454's Avatar
Tnx very much.
Old Apr 17, 2014 | 02:11 PM
magnum454's Avatar
Default battery disconnected
Just wanted to say tnx again to testpoint. Did the window memory reset per your reply and they work perfectly.
Old Apr 17, 2014 | 02:30 PM
Paul Pavlik's Avatar
If you have the Owner;s Manual for your car, the Window Reset Procedure is described in it.
Old Apr 28, 2014 | 03:44 PM
JagMan 98's Avatar
Default not working for long
I have to re-perform this procedure every 72 hours. I have no idea why! Can you or anyone else help?
Old Apr 28, 2014 | 04:00 PM
WhiteXKR's Avatar
Yes, your battery is either in a low state of charge from not using the car for a long time or you need a new battery.
Msteiner
May 16, 2016 12:19 AM
jluckcuck
Nov 6, 2015 07:49 AM
10 XF Premium
Oct 2, 2015 09:22 PM
Swagguar
Sep 30, 2015 01:34 PM
