Battery drains quickly abs
Old Apr 12, 2020 | 10:34 AM
DoubleD98's Avatar
Default Battery drains quickly abs
Battery drains after two days and power widows don't work, tried replacing the fuse, out of ideas
Old Apr 12, 2020 | 01:18 PM
crbass's Avatar
More information? Start with the model year of the car. What fuse did you replace and why since there are a number of fuses. If the battery is drained, a whole bunch of things will not work, why focus on the power windows? Have you tried using an ammeter (a function of a typical voltmeter) to measure the current draw?
Since it's likely a bad battery or some form of short, some idea of the history of your car (i.e. I just pulled it out of a barn where it sat unused for three years) might be helpful.
Someone might be able to help if the problem/background is described sufficiently.
Old Apr 13, 2020 | 08:06 AM
SamtheSham's Avatar
I have had similar problems with booth my Jags. Started after I installed a remote transmitting OBDII unit. Batt. continued to drain after removal of unit. Had to replace both Batt. one only 1 yr. old. I have been told problems arise using the OBDII units if they are not properly started and stopped??? Either Remote, or hand held.
Daim
Aug 16, 2018 06:49 AM
Irish Pappy
Jun 21, 2018 11:17 PM
Aaron 3.2
Sep 18, 2014 03:40 AM
vdpnyc
Apr 21, 2014 08:50 AM
SPIJohn
Dec 5, 2013 09:19 AM
