battery not charging light....can i change the instrument cluster?
Old Nov 23, 2010 | 09:51 AM
newboy's Avatar
Default battery not charging light....can i change the instrument cluster?
The battery not charging light and message was coming up frequently and the mechanic traced it to a slowly failing alternator which has been changed.
But the light still appears sometimes and it has been suggested that the instrument cluster (the 3 big dials behind the steering wheel) are at fault.
I have found a secondhand cluster for not much money - can i just take the old one out (as shown here)
https://www.jaguarforums.com/forum/s...ght=instrument
and put the repalement one in?
or is it much more complicated than that - do the clusters have to be programmed to the car....will the car have an electrical melt down if it doesnt have its original cluster?
mine is a 1997 - i've seen another '97 cluster from an XK8 and a slightly cheaper '99 from an XKR.
Is this feasable?
Old Nov 23, 2010 | 10:06 AM
XKRacer's Avatar
Straight swap no programming needed and if you are lucky you might wipe a few 000s/miles off the trip meter
Old Nov 23, 2010 | 05:04 PM
newboy's Avatar
Thanks for that. I'll get the cheaper one and see how I get on.
Forcedair1
Sep 8, 2025 01:57 PM
redrover41
23
Sep 25, 2015 01:33 PM
carcycle
Sep 7, 2015 10:22 AM
martybmw
Sep 4, 2015 11:05 PM
AL NZ
Sep 4, 2015 08:39 PM
