Battery not charging - x100 XK8 1996
Old Aug 14, 2015 | 09:24 AM
looops's Avatar
Default Battery not charging - x100 XK8 1996
Hi all.
Started getting the message Battery not charging and a bright red light on the 'voltmeter' and dash. It comes and goes so either something loose or something overheating and cooling. Before I lose £200 on an alternator any other suggestions?
Thanks.
Paul.
Old Aug 14, 2015 | 09:41 AM
marvin.d.miller's Avatar
Just to start, unless you have already done this, follow every wire leading away from the alternator, and tighten anything that is loose. You could also remove the alternator and give it a shake to see if anything is loose and rattling in there. I had one go bad and when I gave it a good shake it sounded like I was shaking half a can of screws.....
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
SeanU
Sep 13, 2015 02:45 PM
jaguarbill
Sep 5, 2015 11:43 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
