Battery & Power Steering
Old Nov 10, 2014 | 08:00 PM
Spinedoc2304's Avatar
Default Battery & Power Steering
Hey folks!
All was fine with my 97 XK8 today going to work and doing errands today. Two minutes after start up, a red warning light and " battery not charging" message along with loss of power steering occurred. There was no power loss or other symptoms other than the battery gauge low and blinking red and the air conditioning button blinking red.
Any ideas?
Nick
1997 XK8 convertible.
Old Nov 10, 2014 | 08:17 PM
Jandreu's Avatar
Did you look under the hood? Sounds like a belt let go.
Old Nov 10, 2014 | 08:35 PM
bakntyme's Avatar
Or perhaps under the bonnet.
Old Nov 10, 2014 | 08:41 PM
I haven't looked under my bonnet yet. Too cold and dark out there. Thought I'd get some ideas for the morning
Old Nov 11, 2014 | 09:43 AM
Bryan at Coventry West's Avatar
Yep, definitely sounds like a belt issue. I don't know how long you drove after the symptoms occurred, but the belt might have broken off entirely. If the belt is still there, check to make sure there's enough tension on it to drive the pulleys without slippage.
Old Nov 11, 2014 | 10:41 AM
I pulled the belt off this morning and it was partially off and torn up along a long edge. The car was driven no more than a half mile since the first symptom last night, shut down in the driveway, and restarted for 10 seconds this morning.
Picking up the belt in an hour and hoping to put it in later.
Any good threads or pictorial guides anywhere?
Nick
Old Nov 11, 2014 | 10:56 AM
DevonDavid's Avatar
Have a look here :
https://www.jaguarforums.com/forum/x...acement-83551/
I found there wasn't enough room to get a conventional breaker bar and socket on to the nut, so had to use a smaller ring spanner (wrench ??) like in the picture on the other thread - but then wasn't strong enough to pull against the tension of the spring, so ended up with a 2 foot pipe over the end of the spanner.
That spring is *strong*. and I'm weak and feeble.
Last edited by DevonDavid; Nov 11, 2014 at 10:58 AM. Reason: Had to add "weak and feeble" for honesty reasons
Old Nov 11, 2014 | 11:21 AM
Thanks DevonDavid!
I'll keep everyone posted.
Might want to think about an exercise program to combat that weak and feeble
feeling...Dr. orders.
Nickc
Old Nov 11, 2014 | 03:10 PM
RJ237's Avatar
Doc, if you did start and run for just 10 sec. this morning, you may have a case of cylinder wash due to raw fuel washing the oil from the cylinder walls when the engine is shut off without warming up.
If it doesn't start immediately push the gas pedal to the floor, which shuts off the injectors and turn the engine over for a about 15 sec. then let up on the pedal and see if it fires.
If that fails you may have to pull the plugs and put about 1/4 tsp oil into the cylinders of one bank to get some compression.
This may all be useless information as it may start okay, but I wouldn't want you struggling with a starting problem after fighting with the belt.
Old Nov 11, 2014 | 03:51 PM
Thanks RJ. I changed the belt thanks to this forum and she started right up and ran in the driveway for 10 minutes. Ran it for a 30 minute test drive and it's perfect!
Thanks guys (and gals)
Nick
99xk8guy
May 28, 2024 09:36 PM
Dicque
Sep 19, 2015 12:53 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
