Bent Shifter or another Problem
Old Mar 22, 2008 | 05:19 PM
JagtechOhio's Avatar
Default RE: Bent Shifter or another Problem
Greetings,
The gear selector is pretty stout, I think it is just about impossible for you to have bent it. Then again, I guess it depends how heavy the music is that came from the radio....
The gear selector cable has a steady bracket that is bolted to the left side of your transmission: the outer cable is mounted in a rubber bush and must not move fore and aft when the inner cable moves as you change gears. Either the outer cable is moving at that point, or it has come loose at the shifter end where the adjutment fitting is crimped onto it. The outer cable moving on either end would explain your problem. If in fact that is the case, you have to r&r the center console and replace the cable. Once a good cable is properly adjusted, the adjustment does not change.
Old Mar 22, 2008 | 06:08 PM
No, you won't accomplish anything by pulling things apart unless you have a reason. At the time you may have "bent" the shifter, was it in park with the shift interlock engaged? Or did you have it out of park?
Old Mar 22, 2008 | 06:32 PM
Well,I just went out and looked at a partially stripped '97 XK8 to see if I could provide any other ideas. When you're pulling back on the selector lever with it locked in park, you're pulling against the interlock bracket. If you pull hard enough, either you are going to bend it, or the gear selector.
Old Mar 22, 2008 | 06:59 PM
I'll get back with some pics in a few.
Old Mar 22, 2008 | 07:25 PM
FactoryJaguarTech's Avatar
Just my 2 cents.
The XK8 and XKR are different at the shifter due to the R having the mercedes trans. Regular Xk8 has a rotary switch mounted to the trans for tcm to interpret what gear you are selecting. The XKR has a dual linear switch mounted to the right side of the j-gate. This is what he took off with the two nuts. When you put this back on, make sure that the two pins line up in the switch. It is hard to explain. If one of the pins is not lined up, will prevent shifter from coming back from manual shift to drive. Use a flash light so you can see properly. I believe the shifter hasto be in neutral when installing as the newonss come with a zip tie that you dont cut off until installed.
Hope this helps. I would post procedure for dual linearswitch replacement but not in a convenient place to do so at this time.
Old Mar 22, 2008 | 08:38 PM
Qualifiers:
I will ALWAYS yield to FJT, he has far more experience than I on late model vehicles and his comments are always spot-on;
Components pictured are from a 1997 XK8 N/A;
My latest parts microfische is May 1999;
I have not removed a dual linear switch from an S/C car, that component and the white plastic sliding block are the only different items for S/C variants shown in my microfische.
So I just tried to upload the photos, and "the file is too large".
Try going to my webpage and clicking on 'Photostrem", I'll post everything there.
http://360.yahoo.com/my_profile-wuVb....inZYMs8-?cq=1
Old Mar 23, 2008 | 09:23 AM
jag_genius's Avatar
the dual linear switch has a bit of ajustment on the box.. about 3-4 mm .. which can help adjust the lights not lighting up.. but from my experience i have seen people bend the shifter rod.. to replace.. the whole shifter assembly has to come out and taken apart.. . But they do bend.
Bcrary3
Sep 12, 2021 05:41 AM
neruda
Oct 18, 2015 01:19 PM
jdzubas
Oct 4, 2015 09:14 AM
Bowman
Sep 15, 2015 06:54 AM
Phil G.
Sep 12, 2015 07:42 AM
