A better engine???
Old Sep 13, 2016 | 08:44 AM
oldjaglover's Avatar
Default A better engine???
Regarding the old vs. new cam chain tensioners: Were the supercharged engines of the first generation (1997-2002) built any better than the XK8 engines? Do they, or do they not have the same susceptibility to breaking apart?
Old Sep 13, 2016 | 08:50 AM
RJ237's Avatar
The only significant difference that I can recall is the pistons which give a lower compression ratio to compensate for the boost pressure.
Old Sep 13, 2016 | 08:52 AM
JimmyL's Avatar
They didn't have VVT, so they were a little simpler.
Old Sep 13, 2016 | 08:53 AM
bladerunner919's Avatar
The components that cause concern, mainly the tensioners, are the same. Do the engines have a susceptibility to breaking apart (not including the tensioners)?
Old Sep 13, 2016 | 10:48 AM
RJ237's Avatar
No, but the 4.0, especially the SC version are subject to head gasket failure, especially if overheated. Replacement with the 4.2 mls gasket is the cure.
Old Sep 17, 2016 | 05:52 PM
All great answers. Thank you. I had asked a lady who was selling a 2000(?) XKR if the CCTs had been changed, but she said her mechanic told her "it wasn't worth doing" because it was a "better engine". I thought the CCTs were the same. I'll pass on it.
Thanks again.
aparanschumi
Nov 7, 2016 10:51 AM
pcbrew
XE ( X760 )
Sep 15, 2016 07:03 PM
willtoliv
Sep 13, 2016 12:52 PM
rhscare
Sep 13, 2016 10:02 AM
love&hateXK8
Sep 12, 2016 01:10 PM
