Billet shifter plate arrived! Stunning! 6 Speed
Old Jul 16, 2016 | 10:03 AM
hm1's Avatar
hm1
Default Billet shifter plate arrived! Stunning!
Just got this little gem in the mail, will be installing this weekend. It is stunningly beautiful, worthy of my XKR. I'll update the thread with installed pics this weekend!
Old Jul 16, 2016 | 11:02 AM
hm1's Avatar
hm1
Quick mockup
Old Jul 16, 2016 | 11:41 AM
Jandreu's Avatar
Where did you find this gem and how much? Nice!
Old Jul 16, 2016 | 03:08 PM
hm1's Avatar
hm1
I think he's also got them for the 5 speed cars.
http://m.ebay.com/itm/Jaguar-XK8-XKR-6-SPEED-Billet-Aluminum-Trim-Plate-/302014976178?nav=SEARCH
Jaguar XK8 XKR 6 Speed Billet Aluminum Trim Plate | eBay
Old Jul 28, 2016 | 08:03 PM
dsd's Avatar
dsd
How do you install this?
I can't seem to get my gear knob off (XKR) it just turns freely. Do I need to pull the nut (anyone know if its a screw or a hex or torx)? Also, Do I need to pull the surround?
Thanks!
dsd
Old Jul 29, 2016 | 04:49 PM
hm1's Avatar
hm1
Thanks!
dsd
Will update with pics very soon, I had to put small washers to lift a section----to get everything flush. Looks stunning now!
Old Jul 30, 2016 | 04:24 PM
Sqeeter91's Avatar
Thanks, I just ordered mine!
Old Aug 2, 2016 | 02:00 AM
User 070620's Avatar
Originally Posted by hm1
Quick mockup
spectacular! is trying to make an order even I (it is unclear if dispatch in Italy or not!)
Old Aug 3, 2016 | 04:58 AM
I ordered. please can you tell if there are difficulties in the assembly? you have to make 2 holes? as you have to do to remove the shift knob in Leather-Alluminium R performance?
Old Aug 4, 2016 | 01:35 PM
hm1's Avatar
hm1
Installed. Been driving around with this interior that now looks gorgeous. I've always thought this was the weakest part of this interior, now it has more Jaguarness
Old Aug 4, 2016 | 01:41 PM
hm1's Avatar
hm1
Quick tip: So that it looks as factory perfect as possible, all the lines need to line up flush. I placed a few washers under the center console wood panel to bring it up level. If you don't do, it will look like it's sitting on top of the bezel, not an integrated factory part. Details, make all the difference
Raising console a fraction
Nice and flush
Old Aug 5, 2016 | 01:34 AM
really nice. you had difficulty removing the shift knob?
Old Aug 5, 2016 | 08:41 AM
hm1's Avatar
hm1
My knob came right off with some twisting, pretty easy
Old Aug 6, 2016 | 10:04 PM
SeismicGuy's Avatar
So do you remove the black plastic standard shift piece and replace with this or does this go over the existing?
Doug
Old Aug 6, 2016 | 10:15 PM
hm1's Avatar
hm1
Doug
Goes on top, that's why it ends up slightly raised. But when you put a washer or two under the wood panel, it will be nice and flush.
I was going to do a complete how-to, but my shifter area was cracked in 6 places. I had to first glue it all back together before I could even start this mod.
Old Aug 7, 2016 | 09:17 PM
dsd's Avatar
dsd
Goes on top? What does it screw into (looks like you have hex bolts in it)?
I was going to disassemble the piece are remove the old PRND plate.
Thanks!
dsd
Old Aug 7, 2016 | 10:00 PM
hm1's Avatar
hm1
Thanks!
dsd
Drill through the plastic plate. The screws came with the kit
Old Aug 7, 2016 | 11:39 PM
SeismicGuy's Avatar
I wonder if the original plastic shift piece can be taken off, or is it somehow glued down?
Doug
Old Aug 8, 2016 | 04:10 AM
hm1's Avatar
hm1
Doug
Yes, I'm sure it can be taken off--it's got two screws holding it down from the underside. In order to get to them, you would have to remove the entire assembly.
Old Aug 10, 2016 | 10:42 AM
SailorSam's Avatar
Got mine yesterday.
If you try and remove the old top plate it cracks and breaks. Sigh. Should have asked first.
Yes there are two central screws underneath in line with where the numbers are above.
It is not possible to unplug the circuit board with the lights on at the gear change location. So the new one has to go on over the top of the old one.
You have to drill two holes. Fortunately there are two plastic guides under the old plate that show you exactly where to drill.
Happy to say it looks gorgeous.
I have ordered a replacement black plastic one in case I have to return the car to stock.
Very happy Sailor.
Mark B.
