Bolt Size 4.0 Engine
Old Dec 16, 2017 | 08:06 AM
Chuck Schexnayder's Avatar
Default Bolt Size 4.0 Engine
Son wants to buy a 2001 Jaguar which hasn't run in the last two years.
I would like to try turning the engine over by hand, using a breaker bar and socket, but can't see the drive shaft/pulley nut to know what size it is for the proper socket I need.
Forgot to mention that the engine is Supercharged, if that makes a difference.
Any help would be appreciated.
Old Dec 16, 2017 | 08:26 AM
I believe it is 24mm.
Old Dec 16, 2017 | 09:03 AM
NBCat's Avatar
+1 on 24mm bolt size.
Remember to only rotate the engine in a clock direction when viewed from the front of the vehicle.
Old Dec 16, 2017 | 05:05 PM
Norri and NBCat,
Thanks guys, worked just fine.
BTW engine turned over and with a new btry even started after a couple of trys
Thanks Again
Chuck
ja_slay
Jul 17, 2016 08:35 AM
davemack
May 25, 2016 06:26 PM
CharliePar
Feb 7, 2016 04:16 AM
philwarner
Feb 2, 2016 10:54 AM
TopHatChef
General Tech Help
Mar 4, 2012 02:06 PM
