Bolt (size) for attaching engine hoists
Old Jul 15, 2016 | 06:16 PM
ja_slay's Avatar
Default Bolt (size) for attaching engine hoists
Anyone have the specs on the size and length of the bolts (plus strength rating?) one needs to attach the rear lifting rings to use with an engine hoist on a 1997 XK-8 Convertible engine?
The two threaded holes are found on the aft end of the engine (end nearest the fire wall), about 2-3 inches from the top edge of the engine, driver and passenger side.
I have one pretty large bolt that I found that will go in about one turn but that's all and I don't want to strip the threaded hole. I suspect the thread is too coarse, or more likely, its standard not metric?
Any assistance would be greatly appreciated!
Old Jul 16, 2016 | 02:58 AM
kingfishgrapejam's Avatar
Not sure about those but if you pull the intake you can ****** the rear by the bracket that support the throttle body. That's what I did.
Old Jul 16, 2016 | 12:08 PM
dsnyder586's Avatar
This is NOT ADVISED, but in a pinch I used tie downs on the exhaust manifold.
Old Jul 16, 2016 | 06:02 PM
mrplow58's Avatar
I used the 2 hook eyes on the front of the motor, and wrapped chain around the exhaust manifolds in the back.....Mike
Old Jul 16, 2016 | 10:16 PM
I found it in a search. M14x1.5. Pep boys doesn't stock that size. But the do stock a m14x1.5 wheel stud. I actually picked a couple up to tray and they work perfectly with my hf load balancer.
Old Jul 17, 2016 | 08:35 AM
motorcarman's Avatar
Here is the Jaguar advise from a TSB.
Don't screw the lifting bolt in too far and disturb the oil gallery plug in the head.
bob
File Type: pdf
Jul 21, 2013 04:30 PM
videomaker
Apr 26, 2010 03:57 AM
rawimpact
May 19, 2007 04:06 PM
Mar 18, 2007 12:51 PM
Mar 13, 2007 12:07 PM
