bolt size for upper a-arm 2002 XK8
Old Sep 29, 2024 | 04:49 PM
Drdaffy's Avatar
Default bolt size for upper a-arm 2002 XK8
Can anyone help me with the large upper a-arm bolt size for my 2002 XK8?
Old Sep 29, 2024 | 07:27 PM
motorcarman's Avatar
It is called a FULCRUM SHAFT, UPPER WISHBONE, FRONT SUSPENSION MJA1455AD.
Please be sure to note the shim sizes and placement to reassemble correctly.(thick/thin, fore/aft)
Old Sep 29, 2024 | 09:48 PM
Drdaffy's Avatar
Default Bolt size for upper a-arm on 2002 XK8
Thanks for your reply. I would like the size of the bolt if you have it.
Regards
Old Sep 30, 2024 | 02:17 AM
baxtor's Avatar
Regards
265mm×15mm as best l can measure, but l don't have one off the car so can't be more precise with diameter.
W3IKE
Dec 18, 2022 10:29 AM
wifesjag
Feb 18, 2018 12:01 PM
JTsmks
May 4, 2016 06:21 PM
Collector1
Sep 26, 2015 05:28 PM
jaguarbill
Dec 16, 2013 02:33 PM
