Boot button.
Old Jun 15, 2024 | 01:23 PM
Ant Buck's Avatar
Default Boot button.
My boot button has stopped working but can be opened with the fob. I have soldered the wires a while ago where they break on the boot hinge but if the fob opens the boot there must be power going to the release mechanism ,or is that not necessarily the case.
Old Jun 15, 2024 | 05:32 PM
michaelh's Avatar
Originally Posted by Ant Buck
if the fob opens the boot there must be power going to the release mechanism .
There will be, but I suspect you have either a bad ground, or a wire break between the button and the security module as it's the latter that fires the release mech.
Old Jun 16, 2024 | 02:58 AM
Ant Buck's Avatar
Thank you, will check the wiring for any breaks.
Old Jun 16, 2024 | 05:10 PM
SeismicGuy's Avatar
Just went through this a couple of months ago and it was the body-to-boot harness that apparently had a broken wire (local shop fixed it).
manycars
Dec 3, 2024 10:25 AM
Spud Maat
Aug 19, 2023 08:50 AM
Stefanwest1
Dec 28, 2021 05:39 PM
psyo
Sep 5, 2021 08:32 PM
SamtheSham
Jun 22, 2021 07:18 AM
