Brake, ABS, Check engine lights...help
Old Sep 5, 2016 | 10:52 PM
rhscare's Avatar
Default Brake, ABS, Check engine lights...help
So I started the XK tonight and the lights did not all go off as usual after ignition. The Brake and ABS warning lights stayed on. I shut it off and restarted. This time the same deal, except now with the check engine light joining the party. Also I notice the ASC button in the console was on, and I couldn't switch it off.
The manual says brake fluid could be low, but I checked and that isn't the case.
Any help would be greatly appreciated.
Old Sep 6, 2016 | 04:50 AM
jamdmyers's Avatar
Systematic of a low battery, you said I started the xk tonight, so you don't run it every day? Just sitting there is battery draw ands pending age/condition of battery this is what you might see. Many Many posts on this.
Old Sep 6, 2016 | 05:46 AM
jimbov8's Avatar
+1 on the above. Give the battery a full overnight charge and then see what happens.
Sep 17, 2019 09:27 AM
xkeots
Mar 31, 2016 02:03 AM
aquill1
Feb 7, 2007 02:41 PM
Dec 16, 2006 02:48 AM
Feb 13, 2006 11:40 PM
