Brake fluid change machine flush or old method?
Old Feb 26, 2018 | 07:46 AM
Dercent's Avatar
Default Brake fluid change machine flush or old method?
Thinking about having my brake fluid changed on XK8 1999 and this time having it flushed by machine instead of old school bleeding each wheel off. But I am using Pentosin Super DOT4 like always. Any thoughts on the machine method? Dave in Tampa
Old Feb 26, 2018 | 07:54 AM
Doug's Avatar
What machine? I'm behind the times but to the best of my knowledge the only 'machine' used on a brake fluid flush is simply a pressure bleeder. Easier, faster....but I doubt that the end result is any different
Old Feb 26, 2018 | 08:53 AM
I use Eezibleed which takes pressure from the spare wheel.
A reservoir for the new brake fluid and a one person operation as there is no pedal pumping required.
There are many other versions available based on this same principle.
Old Feb 26, 2018 | 06:57 PM
JagV8's Avatar
I do the same, using a low pressure. Works fine for my car and should with these.
Old Feb 26, 2018 | 08:40 PM
Gus's Avatar
Gus
You have a few ways to go pressure or vacuum. I use vacuum.
https://www.grainger.com/product/MIT..._vc=IDPPLARECS
Mityvac MV8000 Brake Bleeder - Brake Tools
Old Mar 1, 2018 | 02:11 PM
Dercent's Avatar
Default Machine or old method
Well had the fluid replaced via BG machine with my Pentosin super DOT4 today took less than One hour watched them do it, was impressed road tested the car brakes good tried a few stops at 60 and 70 stopped straight as an arrow. So will see how thing progress.
richzak
Sep 28, 2016 10:25 PM
gtjoey
39
Aug 30, 2016 06:02 PM
mrplow58
Apr 7, 2015 08:33 AM
jagosaurus
Jun 25, 2013 12:06 PM
l3uddha
Jun 5, 2012 09:41 PM
