Brake Pads
Old Mar 31, 2008 | 09:34 PM
H20boy's Avatar
Default RE: Brake Pads
pretty sure the pad isn't glued to anything...gotta pull that spring clip out of the caliper piston, you may have broken it off from the pad.
Old Mar 31, 2008 | 09:44 PM
ibjags's Avatar
no glue on pads
possibly some kind of thick antisqueel perhaps and with age and heat its just stuck to the pistontap the pad from the piston it will come off
are you using factory or aftermarket pads?
Old Apr 1, 2008 | 05:51 PM
H20boy's Avatar
Mine just 'rest' against the caliper, and stay pretty snug, no adhesive required. Before I would add any, I would just try it solo, pretty sure you will be just fine. Maybe those weren't the right pads in the first place, and that was the only way the prior owner could get it to stay in place??
Old Apr 1, 2008 | 06:29 PM
jag_genius's Avatar
factory pads have tape/glue on them.
Old Apr 1, 2008 | 09:38 PM
H20boy's Avatar
Didn't know that, very odd!? When I replaced all pads on mine, assumed they were OEM pads, and never saw/felt/dealt with any gluey-tape. So if he uses aftermarket pads, the OP should be ok w/o using any.
H20boy
Dec 24, 2024 03:23 PM
jdzubas
Oct 4, 2015 09:14 AM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
