Brake Pipe Clips
Old Apr 7, 2015 | 05:43 AM
DevonDavid's Avatar
Default Brake Pipe Clips
Quick question .............
How do you remove the small rectangular plastic / nylon clips under the car that secure the brake pipes ? Do they just pull out, or is there a "special technique" ?
As always - thanks for any advice.
Old Apr 7, 2015 | 06:46 AM
gatekeeper's Avatar
If you want to remove them from the car completely, the are held on with ribbed ends similar to these. They are just pushed into a drilled hole in the car. There is a tool to remove them but if your careful you can get them out without it.
PANEL FASTENERS Push-In Clips Christmas Tree™ Clips – Single Head ITW Fastex
Tool.
Amazon.com: Lisle 35260 Plastic Fastener Remover: Automotive Amazon.com: Lisle 35260 Plastic Fastener Remover: Automotive
Old Apr 7, 2015 | 07:17 AM
DevonDavid's Avatar
Thanks Gatekeeper. I have a similar tool so will give it a go.
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Tim Goz
Sep 17, 2015 09:11 AM
TreVoRTasmin
Sep 16, 2015 08:14 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
