Brake pipe routing question
Old Sep 20, 2022 | 07:23 PM
Stamford's Avatar
Default Brake pipe routing question
So, I'm replacing the steel brake pipe (not the flexible hose) from my left front wheel to the ABS block. My question is how important is it to follow the original path from the wheel well to the block. The hard lines appear to have been installed before the engine, etc., making it a very tight work space. I am not sure how, if I duplicate the bends in the original line, I could manipulate it through the fender and behind all the stuff that's in front of it. How criminal would it be if I took a different, "more direct" path to the block? I'm planning on using copper pipe as it's more easily formed. Any tips would be greatly appreciated. Thanks!
Old Sep 21, 2022 | 02:59 AM
The absolute MUST is that the connections at either end don't leak. After that, the shape is just AESTHETICS.
OE pipework looks neat and tidy because it's machine made and fitted before the powertrain. Replicating this is always difficult because brake pipe comes is coils and getting a perfect straight length to begin with is the first challenge.
I use a miniature pipe bender to make good curves. When working around corners, it's often easier to make the bends as the fitting proceeds rather than trying to replicate the entire original shape in one go.
Old Sep 21, 2022 | 05:57 AM
Jon89's Avatar
How and where did your original steel brake line fail?
Old Sep 21, 2022 | 07:20 AM
Stamford's Avatar
Thank you, Graham, that is the answer I was hoping for.
Old Sep 21, 2022 | 07:26 AM
Stamford's Avatar
Angry I did it!
I was hoping no one would ask. I f'd up and managed to twist it right where it enters the wheel well it when I was removing the flex hose. Can't blame the Jag for this.
Old Sep 21, 2022 | 07:48 AM
NorXKR's Avatar
If you take a new route, you have to secure it with new fastening clips or clamps, and in my experience that can be challenging do to lack of space to drill holes etc
Old Sep 21, 2022 | 09:26 AM
Jon89's Avatar
No worries, we all are guilty of breaking other things when working on these cars. I know of at least three times over the years when I have gotten in a hurry with my wife's XK8 and busted something as a result (especially if that something is Jaguar plastic).....
Old Sep 21, 2022 | 10:44 AM
JayJagJay's Avatar
Ain't THAT the truth!
Old Sep 21, 2022 | 01:26 PM
Stamford's Avatar
I am anticipating that.
Old Sep 21, 2022 | 01:27 PM
Stamford's Avatar
Yup, it almost always takes more time when you rush.
Old Sep 26, 2022 | 08:36 PM
Stamford's Avatar
My local mechanic turned the job down, so I was forced to DIM. I started out pretty intimidated by the prospect of fabricating a line and running it. Turned out to be much easier than I expected. I was fortunate that it was the left front brake that I screwed up. That one takes the shortest, most direct path. I didn't even try to duplicate the original route as I'd would have had to remove too many components. But the path I took looks and works just fine. IMPORTANT: The job would have been much more difficult if I has not used nickel/copper pipe. I was so easy to bend that I hardly needed the tube bender. Had I used steel line, I might have been tempted to give up and let someone else do it for me. YouTube taught me all I needed to know about making double-flares for the fittings. In the end, I saved a ton of money.
Old Sep 27, 2022 | 06:08 AM
Jon89's Avatar
Well done....
Old Sep 27, 2022 | 08:43 AM
michaelh's Avatar
Good stuff.
I always use cupro-nickel pipe for replacement brake lines. It's much easier to work with than steel, and it doesn't rust
Old Sep 28, 2022 | 04:15 PM
JagV8's Avatar
Me too.
DUNKS
Nov 29, 2021 04:38 PM
tberry6686
Jul 7, 2020 12:07 PM
Stephen McGuigan
Jul 10, 2019 02:44 AM
fourbyfourbyfar
Nov 2, 2018 02:08 PM
countyjag
Mar 18, 2015 10:40 AM
