brake upgrade
Old May 30, 2012 | 07:43 PM
PetersJags's Avatar
Default brake upgrade
i have XKR and need to replace the front brakes. I have found a set of brembo brakes used from a jag that will suppose to fit my car.Has anyone done this upgrade and did you have to change the mounting bracket or wheel size to fit them in .
thank you
Old May 31, 2012 | 09:13 AM
Stumpy's Avatar
Year and version would be helpful.
Add it to your signature to help people assist you in the future
Old May 31, 2012 | 09:26 AM
XKRacer's Avatar
You will have to tap the upright caliper mounting holes to 14mm, they are normally a fine thread (1.5mm pitch) but I always do it standard 2mm so I can use caphead bolts. The brake disc back plate will need to be removed/replaced, I think you can flatten them out like you would do for the rear, I normally discard them.
The brake flexi will have to be changed, again normally they are a goodridge stainless braided item.... Thats it and away you go
PMKimpton
Aug 3, 2019 08:22 PM
picard
Oct 12, 2015 11:56 AM
wvanepps
Oct 4, 2015 10:01 AM
Pluckie
Oct 3, 2015 07:57 AM
Jefro
Sep 15, 2015 01:44 PM
