Brembo bleed nipple sheared!
Old Aug 3, 2014 | 02:35 PM
azeteg's Avatar
Default Brembo bleed nipple sheared!
Just sheared a bleed nipple off on a Brembo XKR caliper. It is pretty much level with the caliper now. Any good tips on how to get it out?
Old Aug 3, 2014 | 02:50 PM
ccfulton's Avatar
That sucks. I've always been a little afraid of that happening when I have worked on my own brakes. Especially the first time, that sucker was in there tight.
I know you won't have a Sears but you'll get the idea. Probably need something like:
Easy Out
Since the nipple is already hollow you shouldn't need to drill it even.
If you have a machinist friend, you can ask them for advice too.
Old Aug 3, 2014 | 05:39 PM
azeteg's Avatar
Snapped a picture of the mess...
Old Aug 3, 2014 | 05:51 PM
jonscot's Avatar
1 minute job with an easy out - a reverse threaded screw...
Old Aug 3, 2014 | 05:58 PM
There appears sufficient protruding to be able to cut a slot in it and use a manual impact screwdriver.
The visible thread is rusted and a good pre-soak with penetrating oil has to help.
I'd normally apply heat to free a seized bolt or stud but that would damage the silver finish on the caliper.
Mac Allan
Jul 20, 2020 05:46 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
MrWhite
33
Oct 22, 2015 10:29 AM
sg997tt
Oct 9, 2015 10:57 PM
JaguarSV8
Oct 1, 2015 01:58 AM
