Bremo Bleed Nipple Leaking
Old Jul 16, 2017 | 05:32 PM
Rob L's Avatar
Default Bremo Bleed Nipple Leaking
Hi chaps
A couple of months ago i had to split my rear Bremo caliper, once it was put back together i had to bleed the 2 bleed nipples, i remember tightening them up after bleeding, i noticed one still was leaking, i nipped it up some more and it was fine. Now im losing fluid and i can see drips inside of my rear wheel. Does it sound like i should replace the bleed nipples, im worried about tightening it any more incase it breaks.
Old Jul 16, 2017 | 05:49 PM
Aluminium caliper with a steel bleed nipple - you don't want to overtighten that combination.
Have you cleaned the caliper and then checked for the source of the leak?
Old Jul 17, 2017 | 09:25 AM
Rob L's Avatar
My thoughts too, from what i know the nipple should seal on the taper and so i dont know why it is leaking. I have not inspected the caliper yet, i need to remove the rear wheel and have a look. Do you think replacing the nipple would help or should i remove it nd thry and clean the mating surface.
Old Jul 17, 2017 | 03:16 PM
oldmots's Avatar
You might want to inspect the other seals to see if the leak is not the nipple.
Old Jul 17, 2017 | 05:48 PM
Don't speculate - inspect.
You need to determine exactly where the leak is coming from. If it is the nipple then a new one is going to have a better chance of sealing without applying undue force.
Old Jul 18, 2017 | 10:56 PM
baxtor's Avatar
If worse comes to worse there are inserts available on Ebay to repair damaged nipple seats.
Old Jul 19, 2017 | 01:34 PM
Rob L's Avatar
Ok guys many thanks, i will try and get a look tomorrow, been so busy lately.
@baxter many thanks i did not know you could get a tool to repair the seat.
Old Jul 19, 2017 | 03:42 PM
baxtor's Avatar
Rob, it's not a tool as such but an insert and as far as l can see it would involve drilling out and retapping the original nipple seat.
Old Jul 21, 2017 | 03:56 PM
Rob L's Avatar
Thanks baxtor.
I still have not found the time to look. Hopefully over the weekend. I was looking for info on the torque setting that could be used on a bleed nipple but it seems not to exist.
I got a front puncture a couple of days ago, because i drove about for a few miles this ruined the 20" Tyre. As it needed replacing i ended up buying a matching pair of Dunlop sport max, it cost me £343 for the tyres and then £65 for the front and back wheel alignment. So i went home and cried instead of checking my brake fluid leak.
