Brittle electrical couplers
Old Sep 28, 2019 | 03:01 PM
Ktmscott's Avatar
Default Brittle electrical couplers
Ktm Scott here ,
my 99 xk8 has broken and brittle electrical connectors on my VVT and on my throttle pedal tps and on the tps. Any body
found a source for replacement plastic housing prices?
Old Sep 28, 2019 | 05:45 PM
I found connectors for the VVT but have not had to look for the others - will provide PN info shortly
Old Sep 28, 2019 | 05:55 PM
Gus's Avatar
Gus
For what it is worth I needed a new plug for my 99 xk8 crank sensor. After a week of trying to find one I went to Advance Auto and to my surprise they found the plug listed in the computer and I had it the next day.
Gus
www.jagrepair.com
Old Sep 28, 2019 | 06:22 PM
Old Sep 29, 2019 | 12:43 PM
Ktmscott's Avatar
Found and bought the tps coupler on ebay$12 yea!!
found the VVT couplers at auto parts at $40 (seems way way to much $$$)
i think I have a source at my shop on the new 4 stroke race bikes. They all use denso coil packs and I think I have a cheaper source. I’ll post my findings this week if I can find!
Old Sep 29, 2019 | 02:15 PM
kstevusa's Avatar
Attached is link to a Ford-Motorcraft Terminal Assortment. Probably any end you may need
https://parts.ford.com/content/dam/f...il%20Final.pdf
Looks to be very useful. Wells Mfg. also has a assortment
Old Sep 29, 2019 | 06:38 PM
fmertz's Avatar
Rockauto has a number of connectors/pigtails as well, sometimes a variety more extended than expected...
Old Oct 6, 2019 | 01:23 PM
Ktmscott's Avatar
Found and ordered coupler off the part number you provided of eBay and turns out to be the tps on the passenger side of the throttle body. I really need the one on the driver side l/h side of throttle Body. This one has has pins that are smaller and casing is a little different and won’t work on that side. Any ideas out there. Thanks in advance!
Old Oct 6, 2019 | 02:34 PM
Ktmscott's Avatar
The accelerator pedal position sensor is the piece that I need for the l/h side , 4 pin connector. My casing is gone so the rubber seal is holding it in place.
Britrover
Jan 3, 2016 01:39 PM
Lannyl81
Jan 1, 2016 01:21 PM
FastLane
Jan 3, 2013 08:56 PM
H20boy
Jun 25, 2010 11:42 PM
silverj
Apr 6, 2010 02:17 PM
