Broken Oil Cooler
Old May 7, 2012 | 11:54 PM
wallacesims's Avatar
Default Broken Oil Cooler
Am I the only XKR owner who has pulled up too close to the curb and wrecked the oil cooler? I have a 2001 XKR that I got too intimate with the curb and the oil cooler hangs down below the front bumper so naturally it got crunched and started spraying oil all over the parking lot. This is an insanely bad design why put a delicate part like the oil cooler under the front bumper. Does anyone know of a aftermarket fix for this problem?
Old May 8, 2012 | 03:45 AM
WhiteXKR's Avatar
No, you are definitely not the first. https://www.jaguarforums.com/forum/x...es-left-41811/
Remove the two oil cooler mounts, flip them 180 degrees and reinstall them. This will raise the oil cooler about 1-1.5 inches. This will help.
Old May 8, 2012 | 04:00 AM
Originally Posted by WhiteXKR
..........Remove the two oil cooler mounts, flip them 180 degrees and reinstall them. This will raise the oil cooler about 1-1.5 inches......
Seems the location has been modified on the 4.2 litre. The bottom of my oil cooler is more than an inch above the front bumper undertray.
Old May 8, 2012 | 03:26 PM
Stumpy's Avatar
Smile
Thanks. That's good to know
Old Aug 14, 2012 | 12:35 PM
raphell's Avatar
How do I remove the mounts. I have the same problem. My wife parked to close to a concrete stop in a parking lot and now I need to either replace or fix my oil cooler. I was able to remoce the two nuts on the passenger side but the driver side the nuts and posts turn. Any help would be appreciated.
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
Scarecrow
Mar 28, 2016 03:17 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
Busa R
Sep 10, 2015 07:28 PM
