Broken primary chain guide
Old Aug 25, 2018 | 02:13 PM
Ltd's Avatar
Ltd
Default Broken primary chain guide
Old Aug 25, 2018 | 02:17 PM
Ltd's Avatar
Ltd
1998 with 95000 miles
Tried changing just the secondary tensioners, could hear this metal dragging noise when revving.
Old Aug 25, 2018 | 02:25 PM
Ronald Vennell's Avatar
This is why my '97 with 48K miles is getting this work done soon.
Old Aug 25, 2018 | 09:45 PM
Ltd's Avatar
Ltd
Default Half way there
The inboard slipper sheared off at the fastening bolt, slid down and had two grooves worn into it from the lh bank chain.
Chunks are surely in the oil sump.
Putting it all back together tomorrow.
Old Aug 26, 2018 | 09:39 AM
Ltd's Avatar
Ltd
Default Should cam flats align?
I used the CPS hole with the crank licking tool. I used two cam locking bars. Replaced all four chains, tensioners, and primary guide rails.
After torquing everything correctly, I removed bars and CPS locking peg. I turned the crank over with a socket, two revolutions, which brings me back to where I started.
I wanted to see how everything behaved. With the RH cam flats aligned, the LH cam flats are trailing. Is this normal? Will it correct itself with oil pressure on the tensioners? Or have I made an error in the installation process?
Waiting patiently for replies from the group. I'm not fitting the timing cover until I get it right.
Thanks for a great forum.
1998 xk8 4.0 NA.
Old Aug 26, 2018 | 02:53 PM
michaelh's Avatar
Sounds like one bank is off. How much is the LH trailing?
I don't know what is acceptable but - given it's a pretty precise procedure, I imagine little to none.
Good catch on the broken guide, BTW. Could have been messy.
Old Aug 26, 2018 | 04:12 PM
Ltd's Avatar
Ltd
Default Improper lock up
I went back and inserted the CPS lock tool. Rechecked Lh and RH cam flats. RH was perfect. Lh- loosely fit bar, loosened both sprockets and retorqued. I had to turn the cam a few degrees with a channel locking pliers, and snugged down the bar. Somehow, must likely due to My less than perfect eyesight, the lock bar was down but cam flats not perfectly aligned.
Removed CPS lock and cam bars. Rotated several full cycles. Nearly perfect.
Old Aug 27, 2018 | 04:38 AM
Ltd's Avatar
Ltd
Default Poor quality tool
ITiming tool kitStretched and broken think the tool stretch while torquing the sprockets led to the cam flats being out of line. Time for a different tool.
BigTexx
Feb 19, 2015 10:05 AM
Captain K
Jan 15, 2014 09:27 PM
platinummaker
Dec 13, 2013 02:18 PM
prelude4ws
Oct 3, 2010 03:13 PM
