Bump Stops Polyurethane
Old Dec 29, 2018 | 02:09 PM
giandanielxk8's Avatar
Default Bump Stops Polyurethane
In a pinch, I had luck in fitting Volkswagen bump stops to the front shocks of our cars. They were an exact fit. As I was looking at powerflex's site for the next set of bushings I plan on fitting (lower control arm and sway bar bush), I noticed they have a section for bump stops.
They list the BS006 as a Volkswagen front bump stop but don't specify what cars they fit. However, from the picture it looks strikingly similar to the bump stops fitted in our cars but in a superior polyurethane construction.
At $36 I would've tried them out had I learned about these before I fitted new bump stops, sway bar links, shock mounts, and lower shock bush onto my car.
If anyone is feeling adventurous and is willing to try these out please report back on if they fit. I suspect they do, and if so, we would have a viable upgraded bump stop available to us:
https://powerflexusa.com/bumpstopsbu...ont-bs006.aspx
Old Dec 30, 2018 | 10:17 AM
dbtk44's Avatar
Thanks for sharing this! I'm in the "hunting/gathering" stage of a front end rebuild, and looking to use as many polyurethane parts as I can find.
Old Dec 30, 2018 | 11:44 AM
Please let us know if they do fit. It would be nice to make this an official Non - OEM alternative. Powerflex sell both upper and lower front control arm bushings, as well as the sway bar bushings for our cars. Welsh Enterprises sell urethane shock mounts. By then the only rubber parts you would have in the front end would be the lower shock bushing, the sway bar links, and the ball joints.
Old Dec 30, 2018 | 01:50 PM
dbtk44's Avatar
So far I've purchased the Welsh poly shock mounts, poly upper control arm bushings ( brand escapes me at the moment, shipped from the UK ), and poly sway bar bushings. Unfortunately the rebuild is going to have to wait a bit, but..when I get the poly bump stops I will definitely report back on fit and performance.
Old Jan 2, 2019 | 06:05 PM
Cabel's Avatar
Please add this to the "parts interchange" sticky at the top of the forum with additional details!
Old Jan 4, 2019 | 06:30 AM
mermade's Avatar
Powerflex bushes are well recommended for the lifetime guarantee they have https://powerflexstore.co.uk/jaguar-...100-1996-2006/
oddjob2000
Jul 9, 2021 01:31 PM
MaDGeoff
May 25, 2016 03:30 AM
Roadhogg
Aug 5, 2012 03:01 PM
Goldlion
Aug 10, 2010 10:55 AM
lemayconsulting
May 26, 2010 11:27 AM
