Battery Maintenance Charger? - RESOLVED
Old Dec 27, 2018 | 05:21 AM
Doug-xk8's Avatar
Default Battery Maintenance Charger? - RESOLVED
Can anyone recommend a Battery Maintenance Charger For my XK8 I haven't used the car for a couple of weeks and the battery level is low and I am looking to connect a Maintenance charger to it but was looking for recommendations.
Many Thanks Doug
Last edited by GGG; Dec 30, 2018 at 05:05 AM. Reason: Add "RESOLVED" to thread title
Old Dec 27, 2018 | 07:07 AM
Welcome to the forum Doug,
CTEK
Old Dec 27, 2018 | 08:21 AM
zray's Avatar
Originally Posted by Doug-xk8
Can anyone recommend a Battery Maintenance Charger For my XK8 I haven't used the car for a couple of weeks and the battery level is low and I am looking to connect a Maintenance charger to it but was looking for recommendations.<br />Many Thanks Doug
<br /><br /><br />this is the one I've used for many many years. I've even ran over it a few times and it still keeps working You can them at a pretty good price thru Amazon or WalMart.<br />these cars are so particular about battery voltage that I think it's a prudent step to ALWAYS have a battery tender + connected when the car is not being driven overnight or longer. Battery life will be enhanced as well, especially if the battery is the AGM type.<br /><br />http://products.batterytender.com/Dion/Battery-TenderR-Plus.html<img src="https://i.imgur.com/SsjqPDs.jpg"/><br /><br />Z
Old Dec 27, 2018 | 02:33 PM
frankc's Avatar
The best charger around is the CTEK. I have had lots of chargers over the years but this has to be one of the best. I will look it up for you ............. brb
The one below is the one I have. However there are some CTEK a third of the price but it does the basic functions very well. You can simply put the battery on charge and forget about it.
Old Dec 28, 2018 | 04:29 PM
jimmiejag's Avatar
I have CTEK battery maintainers on both my motorcycle and my XK8. Both have AGM batteries and I have had no battery-related problems with either. I have "built-in" both by attaching the CTEK supplied cables with disconnects directly to each battery and simply unplug the charger, disconnect the quick-release disconnects, insert the rubber plug and away I go.
Old Dec 30, 2018 | 04:47 AM
Doug-xk8's Avatar
Many Thanks for all you advice and help with the charger, I have just purchased a CTEK from Amazon and fitted it. straight forward and easy to operate.
Cheers All & Happy New Year.
Doug
Old Dec 30, 2018 | 05:35 AM
frankc's Avatar
Thumbs up
Doug
Great. Happy to help
Old Jan 1, 2019 | 01:07 PM
Dr. Tom's Avatar
My C-tec quit after a year on my 2005 XKR. now have a Schumacker 3 amp working well
Old Jan 4, 2019 | 08:26 AM
scm's Avatar
scm
I had a CTEK 3600 whose mode switch became erratic after a couple of years. I replaced it with an MXS 5.0 and have had no problems with that model for the past 5 years. Great product, and CTEK is the OEM supplier to the prestige manufacturers (Aston, Ferrari, etc) who supply maintainers (at a vast markup).
Old Jan 4, 2019 | 01:30 PM
srpope80's Avatar
This brings a question; although I know my Die Hard (Manufactured by Schumacher) Charger/Maintainer does not recommend against charging with the car leads hooked up, the manual of the charger just says not to START the car with the charger hooked up.
With our finicky electrical system/ECU tests, has anyone thought if it's good/bad/indifferent to charge with the leads still on the vehicle?
Old Jan 4, 2019 | 03:08 PM
JagV8's Avatar
Should be fine. Lots of people leave a ctek-type device connected all the time.
Old Jan 4, 2019 | 09:30 PM
zray's Avatar
I have the battery connected all the time my Battery Tender + is charging. I can't imagine a battery tender getting much use if you had to disconnect the battery leads before using.
Z
Gus
Jun 24, 2021 01:18 AM
JAG_XJ
Nov 4, 2014 11:53 AM
Gus
Nov 8, 2011 02:00 PM
johnfromseattle
Jan 15, 2011 02:33 PM
brgjag
Oct 31, 2010 07:03 PM
